Http-01 challenge fails with Connection refused
riffa.se and 9 more
certbot renew --dry-run -v
--config-dir /config/etc/letsencrypt
--work-dir /config/var/lib/letsencrypt
--logs-dir /config/log/letsencrypt
Processing /config/etc/letsencrypt/renewal/riffa.se.conf
Certificate not due for renewal, but simulating renewal for dry run
Running pre-hook command: /config/etc/letsencrypt/renewal-hooks/pre/10-nginx
Simulating renewal of an existing certificate for riffa.se and 9 more
http-01 challenge for bilder.bstation.se
http-01 challenge for bstation.se
http-01 challenge for joplin.riffa.se
http-01 challenge for riffa.se
http-01 challenge for www.bstation.se
http-01 challenge for www.riffa.se
http-01 challenge for www.zebrabild.se
http-01 challenge for www.zebrabilder.se
http-01 challenge for zebrabild.se
http-01 challenge for zebrabilder.se
Using the webroot path /www for all unmatched domains.
Challenge failed for domain bilder.bstation.se
Challenge failed for domain bstation.se
Challenge failed for domain joplin.riffa.se
Challenge failed for domain riffa.se
Challenge failed for domain www.bstation.se
Challenge failed for domain www.riffa.se
Challenge failed for domain www.zebrabild.se
Challenge failed for domain www.zebrabilder.se
Challenge failed for domain zebrabild.se
Challenge failed for domain zebrabilder.se
Domain: bilder.bstation.se
Type: connection
Detail: 158.174.67.124: Fetching http://bilder.bstation.se/.well-known/acme-challenge/tWngrlqjIzLuu5_XFJW4EeUllP4jD0FdobdWwJS_fqs: Connection refused
Domain: bstation.se
Type: connection
Detail: 158.174.67.124: Fetching http://bstation.se/.well-known/acme-challenge/D__3pw2lL9h_eheaHpvs3oZmSwg7OITyzqrdyuz7LRY: Connection refused
Domain: joplin.riffa.se
Type: connection
Detail: 158.174.67.124: Fetching http://joplin.riffa.se/.well-known/acme-challenge/otxi4onyb_KaVlOAdxH7Qj8a8UlYm-HUW7PUo9vWlWQ: Connection refused
Domain: riffa.se
Type: connection
Detail: 158.174.67.124: Fetching http://riffa.se/.well-known/acme-challenge/iAP1NrgXCDEwiZWPt1dfLJkhdOQB3e6IyFRa7xMVEN0: Connection refused
Failed to renew certificate riffa.se with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
/config/etc/letsencrypt/live/riffa.se/fullchain.pem (failure)
nginx version: nginx/1.28.0
Swag docker on unraid
Bahnhof - sweden
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 5.2.2
All domains fail with connection refused, have tested them all from letsdebug.net succesful.
created a ping file and can access it from the outside:
C:\Users\bbbkada>curl -I http://riffa.se/.well-known/acme-challenge/ping
HTTP/1.1 200 OK
Server: nginx
this certificate has worked before, but not anymore.
running https redirects with exceptions for /.well-known/... on all domains
listen 80;
server_name riffa.se www.riffa.se;
location ^~ /.well-known/acme-challenge/ {
    root /www;
    try_files $uri =404;
    default_type "text/plain";
    access_log off;
    log_not_found off;
/bbbkada
Most likely you are blocking the requests either based on geographic location or user agent.
Not that I know of !?
using a ASUS-WRT Merlin router with all intellegent filterering off.
Wouldn't letsdebug.net detect that ?
Hi @bbbkada ,
I can reach your ping URL from a number of hosts in the UK and US without any issues (and I get "OK" as the response). Requests to .well-known/acme-challenge/ get 404 errors and requests to other paths get 301s as you described. So that all looks okay. I tried with a number of different user-agent headers too.
"Connection refused" says the TCP connection is being actively rejected, rather than just ignored.
Are you able to run a tcpdump on the container that's running nginx (or the machine that's hosting the container)? Might be worth running this (replace interface with the correct interface name) in a separate shell while you run certbot:
tcpdump -n -i interface tcp port 80 or tcp port 443 or icmp
and seeing what comes in. The TCP rules obviously will pick up HTTP and HTTPS, ICMP will let us see if the connections are being rejected in a particular way.
found this pre-hook, guess that explains why the container OS resets the requests ?
root@2c4728d768bc:/config/etc/letsencrypt/renewal-hooks/pre# cat 10-nginx
#!/usr/bin/with-contenv bash
shellcheck shell=bash
shellcheck source=/dev/null
. /config/.donoteditthisfile.conf
if [[ ! "${ORIGVALIDATION}" = "dns" ]] && [[ ! "${ORIGVALIDATION}" = "duckdns" ]]; then
if pgrep -f "nginx:" >/dev/null; then
s6-svc -d /run/service/svc-nginx
fi
fi
Standard pre-hook in swag container.
I tried a renewal and it works just fine now !
Yeah, if it's stopping nginx (and presumably restarting it in a post-renewal hook?) that would explain a lot. Well spotted :slight_smile: Glad to hear it's working again.
