Renewal "Connection Refused"
iassist.ru
www.iassist.ru
current certificate crt.sh ID 3357996933
certbot renew --dry-run
http-01 challenge for iassist.ru
http-01 challenge for www.iassist.ru
Challenge failed for domain iassist.ru
Challenge failed for domain www.iassist.ru
Attempting to renew cert (iassist.ru) from /etc/letsencrypt/renewal/iassist.ru.conf produced an unexpected error: Some challenges have failed.. Skipping.
Domain: iassist.ru
Type: connection
Detail: Fetching
http://iassist.ru/.well-known/acme-challenge/ROdY-0ZUybBa9d_u6v5Jr3UE0Bpea_3OUP8t0KpKYRQ:
Connection refused
nginx/1.19.3
centos-release-8.2-2.2004.0.2.el8.x86_64
no, this is a home system
no
certbot 1.9.0
Your port 443 (HTTPS) is working fine, but as the name already suggests, the http-01 challenge uses the HTTP protocol on port 80. And your nginx isn't answering on port 80: curl: (7) Failed to connect to iassist.ru port 80: Connection refused
So you'll need to open port 80 somehow: perhaps in nginx? Perhaps in your firewall? Perhaps in your (NAT) router?
Thanks a lot, it worked. I checked it with curl, but from the internal network, and the error was in the settings of the router.
