My domain is: madisonmycologicalsociety.com
I ran this command: certbot renew --dry-run
Processing /etc/letsencrypt/renewal/madisonmycologicalsociety.com.conf
http-01 challenge for madisonmycologicalsociety.com
http-01 challenge for www.madisonmycologicalsociety.com
Waiting for verification…
Attempting to renew cert (madisonmycologicalsociety.com) from /etc/letsencrypt/renewal/madisonmycologicalsociety.com.conf produced an unexpected error: Failed authorization procedure. madisonmycologicalsociety.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://madisonmycologicalsociety.com/.well-known/acme-challenge/SlQu6j6nTa3XRX3IGq4RZJR1HlF-sKDdh8bY3OIp00M: Connection refused, www.madisonmycologicalsociety.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://www.madisonmycologicalsociety.com/.well-known/acme-challenge/W6kuG2NgCT4hot-zp0p_KdLhchuT2hlLu0u-QlwUddc: Connection refused. Skipping.
/etc/letsencrypt/live/madisonmycologicalsociety.com/fullchain.pem (failure)
Domain: madisonmycologicalsociety.com
Type: connection
Detail: Fetching
Connection refusedDomain: www.madisonmycologicalsociety.com
Type: connection
Detail: Fetching
Connection refusedTo fix these errors, please make sure that your domain name was
My web server is (include version): OpenLiteSpeed 1.4.46
The operating system my web server runs on is (include version): Ubuntu 18.04.2 LTS
My hosting provider, if applicable, is: Digital Ocean
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): nope!
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
I’m not sure exactly what the problem is and I’m also relatively new to this stuff. We have a google domain and were using google’s DNS servers for our A and AAAA records, but I think when I issued our original certificate it was on Digital Ocean’s name servers, so I switched it back to try and renew the certs. Still getting the connection refused errors… I tried renewing by ssh-ing from my phone as well (using a different internet service) and also received the same errors… any help would be greatly appreciated.
