Connection Refused When Requesting for New Certificate
My domain is: dev.bookshelf.sun-asterisk.ph
I ran this command: sudo ./init-letsencrypt.sh
http-01 challenge for dev.bookshelf.sun-asterisk.ph
Using the webroot path /var/www/certbot for all unmatched domains.
Challenge failed for domain dev.bookshelf.sun-asterisk.ph
   Domain: dev.bookshelf.sun-asterisk.ph
   Type:   connection
   Detail: Fetching
   http://dev.bookshelf.sun-asterisk.ph/.well-known/acme-challenge/X-fDlMuF5MGEu4wynoFEyi50xMpvmQ1Q_FYtKnHRXZE:
   Connection refused
My web server is (include version): nginx:1.15-alpine (Used as image in docker)
The operating system my web server runs on is (include version): CentOS Linux 7 (Core)
My hosting provider, if applicable, is: dotPH
I am using docker with my Rails Application.
Hi @CharlotteDS
there is a check of your domain, two days old - https://check-your-website.server-daten.de/?q=dev.bookshelf.sun-asterisk.ph
104.248.152.54 -2 1.800 V
ConnectFailure - Unable to connect to the remote server
https://dev.bookshelf.sun-asterisk.ph/
104.248.152.54 -2 1.796 V
http://dev.bookshelf.sun-asterisk.ph/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
104.248.152.54 -2 1.813 V
Only blocked connections.
If you want to use http validation, a running webserver and an open port 80 are required.
http://dev.bookshelf.sun-asterisk.ph/.well-known/acme-challenge/random-filename
should answer with a http status 404 - Not Found.
I only followed this article: https://medium.com/@pentacent/nginx-and-lets-encrypt-with-docker-in-less-than-5-minutes-b4b8a60d3a71.
I already have a working application. I added a link between my app and nginx in the docker-compose.yml.
There
is another user. Same tutorial, same problem.
Perhaps the tutorial is incomplete.
I already solved the issue.
I accidentally erased a word in the configuration file.
