Connection refused
stage.devopsloft.io
certbot certonly -n -v --debug-challenges --debug --webroot -w /var/www/certbot --staging --email liora@devopsloft.io -d stage.devopsloft.io --rsa-key-size 4096 --agree-tos
Challenges loaded. Press continue to submit to CA. Pass "-v" for more info about
challenges.
    Domain: stage.devopsloft.io
    Type: connection
    Detail: Fetching
    http://stage.devopsloft.io/.well-known/acme-challenge/0PFAw1V-9oCg8d_bx8lZURygq1pJRrqe30Vk-5SpEPk:
    Connection refused
  • Your account credentials have been saved in your Certbot
nginx 1.18.0
nginx:stable container image
AWS/ECS
no
certbot/certbot:latest container image - v1.8.0
Hi @lioramilbaum
there is no answer. Now not a Connection refused, instead, a timeout. See https://check-your-website.server-daten.de/?q=stage.devopsloft.io
http://stage.devopsloft.io/ 54.73.94.30 -14 10.030 T
Timeout - The operation has timed out
https://stage.devopsloft.io/ 54.73.94.30 -14 10.030 T
http://stage.devopsloft.io/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 54.73.94.30 -14 9.997 T
Only timeouts.
If you want to use webroot, a running webserver is required. Runs the http port 80?
curl http://stage.devopsloft.io/
from that machine?
Do you run certbot on that machine?
If yes, it's a router / firewall problem.
Thanks for the prompt reply. With your insight, I've managed to solve the problem.
Happy to read that you have found a solution. Thanks reporting back :+1:
