Docker certbot failed,Connection refused
bookstack.quantox.dev
docker-compose run --rm certbot -v certonly --webroot --webroot-path /var/www/certbot/ -d bookstack.quantox.dev
Requesting a certificate for bookstack.quantox.dev
http-01 challenge for bookstack.quantox.dev
Using the webroot path /var/www/certbot for all unmatched domains.
Challenge failed for domain bookstack.quantox.dev
Domain: bookstack.quantox.dev
Type: connection
Detail: *******: Fetching http://bookstack.quantox.dev/.well-known/acme-challenge/4CMOd8_q2m3f2pwZ54WfPAK0LUai-dbHxo5GYGfYIQ0: Connection refused
Nginx
Ubuntu 20.04
Cloudflare
no
docker image latest
It looks like the webserver you have running in your docker-compose set up, did not start properly.
Either that, or your domain is not pointing to the right server.
I am not sure about that. I am running this server on AWS Ec2 Instance. How to check if domain is not pointing to the right or wring server?
You could run curl ifconfig.me and confirm that the output is 18.158.222.31.
If the IP address is correct, then check that nginx is running before you run certbot, and that port 80 on the nginx container is being exposed to the host.
I checked all that. This is part of the docker-compose file
webserver:
image: nginx:alpine
container_name: webserver
restart: unless-stopped
tty: true
ports:
- "443:443"
- "80:80"
volumes:
- ./:/var/www
- ./nginx/conf.d/:/etc/nginx/conf.d/
- ./certbot/www:/var/www/certbot
- ./certbot/conf/:/etc/letsencrypt
Is the webserver container running right now? I can't access it.
certbot:
image: docker.io/certbot/certbot:latest
volumes:
I will double check and will respond soon.
Note that I'm not a docker expert, but shouldn't the certbot docker command also have some volume options? For the /var/www/certbot/ path as wel as for /etc/letsencrypt/, so the certificates will be saved persistently instead of ephemeral?
