My domain is: veganvault.de
I ran this command: certbot certonly -webroot -w /var/www/certbot --email -d veganvault.de -d www.veganvault.de --rsa-key-size 4096 --agree-tos --force-renewal
(included in the init-letsencrypt.sh, ran with “sudo ./init-letsencrypt.sh”)
http-01 challenge for veganvault.de
http-01 challenge for www.veganvault.de
Using the webroot path /var/www/certbot for all unmatched domains.
Challenge failed for domain veganvault.de
Challenge failed for domain www.veganvault.de
Domain: veganvault.de
Type: connection
Detail: Fetching
http://veganvault.de/.well-known/acme-challenge/_fSX4dkfmA7mtgYdMdwcPWRHMxkMW 6DfWsnf7rKINws:
Connection refused
Domain: www.veganvault.de
Type: connection
Detail: Fetching
http://www.veganvault.de/.well-known/acme-challenge/cfJTAHsrjUuJiU8P2dK7K-a06 WjLOMY7vag9IVpUxus:
Connection refused
My web server is (include version): nginx /1.14.0
The operating system my web server runs on is (include version): Ubuntu/18.04.3
My hosting provider, if applicable, is: DigitalOcean
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): No, I’m using PuTTY 0.70
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot/0.31.0
I followed this tutorial: https://medium.com/@pentacent/nginx-and-lets-encrypt-with-docker-in-less-than-5-minutes-b4b8a60d3a71
Folder Structure
project
│ docker-compose.yml
│ init-letsencrypt.sh
└───app
│ │ Dockerfile
│ │ <Website contents>
└───certbot
│ └─── conf
│ │ │ options-ssl-nginx.conf
│ │ │ ssl-dhparams.pem
│ │ └─── accounts
│ │ └─── csr
│ │ └─── keys
│ │ └─── live
│ │ └─── renewal
│ │ └─── renewal-hooks
│ └─── www
└───nginx
│ Dockerfile
└─── conf.d
│ app.conf
I didnt include everything from the certbot directory (too much), but I suppose it’s usually the same anyway.
docker-compose.yml
version: '3'
services:
flask:
build:
context: app
dockerfile: Dockerfile
container_name: veganvault
image: digitalocean.com/flask-python:3.6
restart: unless-stopped
environment:
APP_ENV: "prod"
APP_NAME: veganvault
APP_DEBUG: "False"
APP_PORT: 5000
MONGODB_DATABASE: <db>
MONGODB_USERNAME: <user>
MONGODB_PASSWORD: <pw>
MONGODB_HOSTNAME: mongodb
expose:
- 5000
volumes:
- appdata:/var/www
depends_on:
- mongodb
networks:
- frontend
- backend
mongodb:
image: mongo:4.0.8
container_name: mongodb
command: mongod --auth
environment:
MONGO_INITDB_ROOT_USERNAME: <dbname>
MONGO_INITDB_ROOT_PASSWORD: <dbpw>
MONGO_INITDB_DATABASE: <dbname>
MONGODB_DATA_DIR: /data/db
MONDODB_LOG_DIR: /dev/null
volumes:
- mongodbdata:/data/db
networks:
- backend
nginx:
build:
context: nginx
image: nginx:1.15-alpine
container_name: nginx
environment:
APP_ENV: "prod"
APP_NAME: "nginx"
APP_DEBUG: "true"
SERVICE_NAME: "nginx"
ports:
- "80:80"
- "443:443"
volumes:
- ./nginx:/etc/nginx/conf.d
# - nginxdata:/var/log/nginx
- ./certbot/conf:/etc/letsencrypt
- ./certbot/www:/var/www/certbot
depends_on:
- flask
networks:
- frontend
certbot:
image: certbot/certbot
volumes:
networks:
frontend:
driver: bridge
backend:
driver: bridge
volumes:
mongodbdata:
driver: local
appdata:
driver: local
nginxdata:
driver: local
app/Dockerfile
FROM python:3.7.3-alpine3.8
ENV GROUP_ID=1000 \
USER_ID=1000
WORKDIR /var/www/
ADD ./requirement.txt /var/www/requirement.txt
RUN pip install -r requirement.txt
ADD . /var/www/
RUN pip install gunicorn
RUN addgroup -g $GROUP_ID www
RUN adduser -D -u $USER_ID -G www www -s /bin/sh
USER www
EXPOSE 5000
USER root
CMD [ "gunicorn", "-w", "3", "--bind", "0.0.0.0:5000", "wsgi"]
RUN apk --update add bash nano
ENV STATIC_URL /static
ENV STATIC_PATH var/www/app/static
COPY ./requirement.txt /var/www/requirement.txt
nginx/Dockerfile
FROM alpine:3.8
RUN apk --update add nginx && \
ln -sf /dev/stdout /var/log/nginx/access.log && \
ln -sf /dev/stderr /var/log/nginx/error.log && \
mkdir /etc/nginx/sites-enabled/ && \
mkdir -p /run/nginx && \
mkdir /etc/letsencrypt/ && \
rm -rf /etc/nginx/conf.d/default.conf && \
rm -rf /var/cache/apk/*
COPY conf.d/app.conf /etc/nginx/conf.d/app.conf
EXPOSE 80
EXPOSE 443
CMD ["nginx", "-g", "daemon off;"]
init-letsencrypt.sh
#!/bin/bash
if ! [ -x "$(command -v docker-compose)" ]; then
echo 'Error: docker-compose is not installed.' >&2
exit 1
fi
domains=(veganvault.de www.veganvault.de)
rsa_key_size=4096
data_path="./certbot"
email="uttecht.dev@gmail.com" # Adding a valid address is strongly recommended
staging=0 # Set to 1 if you're testing your setup to avoid hitting request limits
if [ -d "$data_path" ]; then
read -p "Existing data found for $domains. Continue and replace existing certificate? (y/N) " decision
if [ "$decision" != "Y" ] && [ "$decision" != "y" ]; then
exit
fi
fi
if [ ! -e "$data_path/conf/options-ssl-nginx.conf" ] || [ ! -e "$data_path/conf/ssl-dhparams.pem" ]; then
echo "### Downloading recommended TLS parameters ..."
mkdir -p "$data_path/conf"
curl -s https://raw.githubusercontent.com/certbot/certbot/master/certbot-nginx/certbot_nginx/_internal/tls_configs/options-ssl-nginx.conf > "$data_path/conf/options-ssl-nginx.conf"
curl -s https://raw.githubusercontent.com/certbot/certbot/master/certbot/certbot/ssl-dhparams.pem > "$data_path/conf/ssl-dhparams.pem"
echo
fi
echo "### Creating dummy certificate for $domains ..."
path="/etc/letsencrypt/live/$domains"
mkdir -p "$data_path/conf/live/$domains"
docker-compose run --rm --entrypoint "\
openssl req -x509 -nodes -newkey rsa:1024 -days 1\
-keyout '$path/privkey.pem' \
-out '$path/fullchain.pem' \
-subj '/CN=localhost'" certbot
echo
echo "### Starting nginx ..."
docker-compose up --force-recreate -d nginx
echo
echo "### Deleting dummy certificate for $domains ..."
rm -Rf /etc/letsencrypt/live/$domains && \
rm -Rf /etc/letsencrypt/archive/$domains && \
rm -Rf /etc/letsencrypt/renewal/$domains.conf" certbot
echo
echo "### Requesting Let's Encrypt certificate for $domains ..."
#Join $domains to -d args
domain_args=""
for domain in "${domains[@]}"; do
domain_args="$domain_args -d $domain"
done
# Select appropriate email arg
case "$email" in
"") email_arg="--register-unsafely-without-email" ;;
*) email_arg="--email $email" ;;
esac
# Enable staging mode if needed
if [ $staging != "0" ]; then staging_arg="--staging"; fi
certbot certonly --webroot -w /var/www/certbot \
$staging_arg \
$email_arg \
$domain_args \
--rsa-key-size $rsa_key_size \
--agree-tos \
--force-renewal" certbot
echo
echo "### Reloading nginx ..."
docker-compose exec nginx nginx -s reload
upstream app_server {
server flask:5000;
listen 80;
server_name veganvault.de www.veganvault.de;
root /var/www/certbot;
listen 443 ssl;
ssl_certificate /etc/letsencrypt/live/veganvault.de/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/veganvault.de/privkey.pem;
include /etc/letsencrypt/options-ssl-nginx.conf;
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
proxy_pass http://veganvault.de;
proxy_set_header Host $http_host;
I hope I provided all required information.
Thanks!
