Nginx with Docker. Certbot failed to authenticate some domains. Connection refused
I'm new to Docker and and Certbot and have following error, but not sure why the connection is being refused... Any ideas?
muaythai-shop.com
docker-compose -f docker-compose.prod.yml run --rm certbot certonly --webroot --webroot-path /var/www/certbot/ -d muaythai-shop.com
Account registered.
Requesting a certificate for muaythai-shop.com
Domain: muaythai-shop.com
Type: connection
Detail: 104.248.36.46: Fetching http://muaythai-shop.com/.well-known/acme-challenge/M6uTKHdz-k2J2AoDAao0xcwQ28ZIXs9mNo2dWTcQ-rM: Connection refused
ERROR: 1
nginx:1.23.3-alpine
Ubuntu 20.04
DigitalOcean
no I'm using Docker
certbot 1.29.0
Hi @sudo_sudo, and welcome to the LE community forum :slight_smile:
The HTTP connection was refused.
Is your HTTP site available from the Internet?
It was accessible via domain name, but since I have added this file to the root folder:
nginx/conf/muaythai-shop.com
and these lines of code to the docker-compose file it is not accessible anymore:
      - 443:443
    volumes:
      - ./nginx/conf/:/etc/nginx/conf.d/:ro
      - ./certbot/www:/var/www/certbot/:ro
    restart: unless-stopped
  certbot:
    image: certbot/certbot:latest
    volumes:
      - ./certbot/www/:/var/www/certbot/:rw
The Nginx config file is on the right side of the screenshot, but not sure if it is correct...
Please show this file:
    listen 80;
    listen [::]:80;
    server_name muaythai-shop.com www.muaythai-shop.com;
    server_tokens off;
        root /var/www/certbot;
        return 301 https://muaythai-shop.com$request_uri;
    listen 443 default_server ssl http2;
    listen [::]:443 ssl http2;
    server_name muaythai-shop.com;
    ssl_certificate /etc/nginx/ssl/live/muaythai-shop.com/fullchain.pem;
    ssl_certificate_key /etc/nginx/ssl/live/muaythai-shop.com/privkey.pem;
    	try_files $uri $uri/ =404;
That can only be used once in the entire configuration.
Why did you use it there?
Doesn't that already exist elsewhere?
Also, HTTP redirects to HTTPS.
HTTPS has no root path.
It says "try_files" - try them where?
Thanks for your time! It seems to be rather a wrong Nginx configuration than a certbot issue...
About this:
default_server
I have found a config file on the bottom of the following website and and have adapted it as good as I can to my URL.
About this:
try_files
I have found it in the example of DigitalOcean but don't know what it means.
Keep looking...
Until you come across the "root" directive.
Then use that one too.
