Certbot failed to authenticate some domains (authenticator: webroot). Connection refused
My domain is: wallet.telecelplay.io
I ran this command: docker-compose run --rm --entrypoint "
certbot certonly --webroot -w /var/www/certbot
--register-unsafely-without-email
-d wallet.telecelplay.io
--rsa-key-size 4096
--agree-tos
--force-renewal -v" certbot
It produced this output: Creating dummy certificate for wallet.telecelplay.io ...
Creating env-prod_certbot_run ... done
Generating a RSA private key
writing new private key to '/etc/letsencrypt/live/wallet.telecelplay.io/privkey.pem'
Starting nginx ...
Recreating nginx ... done
Deleting dummy certificate for wallet.telecelplay.io ...
Requesting Let's Encrypt certificate for wallet.telecelplay.io ...
Requesting a certificate for wallet.telecelplay.io
http-01 challenge for wallet.telecelplay.io
Using the webroot path /var/www/certbot for all unmatched domains.
Challenge failed for domain wallet.telecelplay.io
Domain: wallet.telecelplay.io
Type: connection
Detail: 51.158.67.92: Fetching http://wallet.telecelplay.io/.well-known/acme-challenge/JyIyAQvyx_IE6PkNq_IziIYfY4iSYYEpXzMk1Bsp0eQ: Connection refused
ERROR: 1
Reloading nginx ...
Error response from daemon: Container f03d8084e9232d6ba3103b6ec834e16a7c2f8a3620abff5083efee765aedffad is restarting, wait until the container is running
My web server is (include version): nginx:1.15.12
The operating system my web server runs on is (include version):linux
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.29.0
Hi @Avi21, and welcome to the LE community forum :slight_smile:
Please remove this from your test (and never use it again):
Furthermore, tell whoever gave you those instructions to remove it from any such instructions.
You will need a working HTTP site before you can use HTTP authentication to obtain a certificate.
Thanks a lot @rg305 :pray:.
