ACME Challenges failed, connection refused
My domain is: incog.rioctos.com
I ran this command: ./init-letsencrypt.sh
(This is from GitHub - wmnnd/nginx-certbot: Boilerplate configuration for nginx and certbot with docker-compose)
  Domain: incog.rioctos.com
  Type:   connection
  Detail: 77.68.75.108: Fetching http://incog.rioctos.com/.well-known/acme-challenge/uGkQuZAJnEuiHnHPOPnuuupFdgqdMP-cfsaRl9_hKZI: Connection refused
  Domain: www.incog.rioctos.com
  Type:   connection
  Detail: 77.68.75.108: Fetching http://www.incog.rioctos.com/.well-known/acme-challenge/BUDs3tH4ySNWD_N9zhYqTPiYWwbiKwiBWaUsElbKPuQ: Connection refused
ERROR: 1
My web server is (include version): Nginx 1.18.0
The operating system my web server runs on is (include version): Ubuntu 2.20
My hosting provider, if applicable, is: Ionos VPS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.5.0
Hi @savage_hz, and welcome to the LE community forum :slight_smile:
HTTP [TCP port 80] is not open.
curl -Ii incog.rioctos.com
And I also have set firewall rules for all ports open.
How do I enable HTTP TCP port 80?
Thanks
Ping uses ICMP by default, not TCP.
You should talk with your hosting service about that. Is 77.68.75.108 still your public IP address? Because that is what the public DNS has for your domain.
Also, in the past 8 days you've received 4 certs already. Why do you need another one? And, what changed to prevent access to port 80 now when it was working before?
Note also there is a Rate Limit of 5 certs / week with the identical names. You should use the Staging System while you are testing to avoid being rate limited.
https://tools.letsdebug.net/cert-search?m=domain&q=incog.rioctos.com&d=744
