Connection refused
My domain is:melochenator.com
I ran this command: sudo certbot-auto certonly -a webroot --webroot-path=/var/www/melochenator.com/www/html/ -d melochenator.com -d www.melochenator.com
My web server is (include version):nginx
The operating system my web server runs on is (include version):Ubuntu 14.04.5 LTS \n \
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):certbot 0.28.0
Requesting to rerun /usr/local/sbin/certbot-auto with root privileges…
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificate name you requested and isn’t close to expiry.
(ref: /etc/letsencrypt/renewal/melochenator.com.conf)
What would you like to do?
1: Keep the existing certificate for now
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
http-01 challenge for melochenator.com
http-01 challenge for www.melochenator.com
Using the webroot path /var/www/melochenator.com/www/html for all unmatched domains.
Waiting for verification…
Failed authorization procedure. melochenator.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://melochenator.com/.well-known/acme-challenge/UGy2DC3yZRvkYHx6NZpahpYrvPVhzybQAM3fro0NJsg: Connection refused, www.melochenator.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.melochenator.com/.well-known/acme-challenge/H6ap8hQ5NUR-LogV-AyIxjOyTQ4h4nE0UBBS58yZh14: Connection refused
Is nginx even running? I’m getting a connection refused too. If it is running, does it also run HTTP on port 80?
root@melochenator:~# netstat -nltp nginx
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 1073/sshd
tcp 0 0 0.0.0.0:25 0.0.0.0:* LISTEN 1678/master
tcp 0 0 127.0.0.1:6010 0.0.0.0:* LISTEN 24574/0
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 25540/nginx -g daem
tcp 0 0 127.0.0.1:6011 0.0.0.0:* LISTEN 24984/2
tcp 0 0 0.0.0.0:6556 0.0.0.0:* LISTEN 1064/xinetd
tcp 0 0 0.0.0.0:5666 0.0.0.0:* LISTEN 1472/nrpe
tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 15201/php-fpm.conf)
tcp 0 0 0.0.0.0:3306 0.0.0.0:* LISTEN 24664/mysqld
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 634/rpcbind
tcp6 0 0 :::38899 :::* LISTEN 11408/java
tcp6 0 0 :::22 :::* LISTEN 1073/sshd
tcp6 0 0 :::25 :::* LISTEN 1678/master
tcp6 0 0 ::1:6010 :::* LISTEN 24574/0
tcp6 0 0 ::1:6011 :::* LISTEN 24984/2
tcp6 0 0 :::5666 :::* LISTEN 1472/nrpe
tcp6 0 0 :::37799 :::* LISTEN 11142/java
tcp6 0 0 :::111 :::* LISTEN 634/rpcbind
tcp6 0 0 :::80 :::* LISTEN 25540/nginx -g daem
it is showing on port 80 and 443
Hi @Aku
is there a firewall or something else? Port 80 is active blocked ( https://check-your-website.server-daten.de/?q=melochenator.com ):
• http://melochenator.com/
52.3.37.37 -2 1.323 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 52.3.37.37:80
• http://www.melochenator.com/
52.3.37.37 -2 1.307 V
• https://melochenator.com/
52.3.37.37 302 Melochenator 2.304 N
Certificate error: RemoteCertificateNameMismatch
• https://www.melochenator.com/
52.3.37.37 302 Melochenator 2.073 B
• Melochenator 200 1.980 N
• Melochenator 200 1.973 B
• http://melochenator.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
• http://www.melochenator.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
You need an open port 80. There may be a redirect http -> https, Letsencrypt follows such redirects. But the first GET requires port 80 + http.
any other way i can run certbot command on prot 443
You can use tls-alpn-01, but Certbot doesn't support it. Acme.sh support this validation.
Why isn't it possible to open port 80 and add a 301 redirect http -> https?
A closed port 80 has nothing to do with a "more secure system".
i have fixed the issue now i am getting this messsage
ubuntu@melochenator:~$ sudo certbot-auto certonly -a webroot --webroot-path=/var/www/melochenator.com/www/html/ -d melochenator.com -d www.melochenator.com
Failed authorization procedure. www.melochenator.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.melochenator.com/.well-known/acme-challenge/l_rjx6Zy-DES4C48o57HWbkN73QN_1a-Of37lx-CtbM: “\r\n400 The plain HTTP request was sent to HTTPS port\r\n<body bgcolor=“white”>\r\n
400 B”
Now your http is broken, Bad Request ( melochenator.com - Make your website better - DNS, redirects, mixed content, certificates ):
52.3.37.37 400 0.213 M
Bad Request
Bad Request
52.3.37.37 302 Melochenator 2.320 B
52.3.37.37 302 Melochenator 2.123 N
• Melochenator 200 2.110 B
• Melochenator 200 2.126 N
• https://melochenator.com:80/
52.3.37.37 302 Melochenator 2.296 Q
• https://www.melochenator.com:80/
52.3.37.37 302 Melochenator 2.117 Q
52.3.37.37 400 0.217 M
Bad Request
Bad Request
Looks like you send port 80 to the https-port, so this wrong combination
has a http status 302.
Letsencrypt requires a working http port, not a Bad Request - status 400.
can you please check i am on new method. i mean please check running new certbot-auto not on old one tls-sni-01
website name melochenator.com
Now you have another error:
52.3.37.37 302 https://melochenator.com/ 0.210 A
52.3.37.37 302 https://www.melochenator.com/ 0.216 A
52.3.37.37 -2 1.310 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 52.3.37.37:443
52.3.37.37 -2 1.313 V
52.3.37.37 302 https://melochenator.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.217 A
52.3.37.37 302 https://www.melochenator.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.214 A
• https://melochenator.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de -2 1.310 V
• https://www.melochenator.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de -2 1.317 V
Your http works and has correct redirects to https (which is good!).
But your https is blocked, looks like a firewall.
PS: My tool is public visible, so you can check your website and compare the result with other sites.
The last checks (https + /.well-known/acme-challenge - subdirectory) should produce a http status 404 and a Grade A.
i fixed just please verify i am with new cert and not using TLS-SNI-01?
I can't see that. Check your log, there you should find the authentication method:
/var/log/letsencrypt/letsencrypt.log
2019-01-27 14:24:18,497:DEBUG:certbot.storage:Writing new private key to /etc/letsencrypt/archive/melochenator.com/privkey12.pem.
2019-01-27 14:24:18,497:DEBUG:certbot.storage:Writing certificate to /etc/letsencrypt/archive/melochenator.com/cert12.pem.
2019-01-27 14:24:18,498:DEBUG:certbot.storage:Writing chain to /etc/letsencrypt/archive/melochenator.com/chain12.pem.
2019-01-27 14:24:18,498:DEBUG:certbot.storage:Writing full chain to /etc/letsencrypt/archive/melochenator.com/fullchain12.pem.
2019-01-27 14:24:18,626:DEBUG:certbot.plugins.selection:Requested authenticator webroot and installer <certbot.cli._Default object at 0x7fdc9e7d7190>
2019-01-27 14:24:18,774:DEBUG:certbot.cli:Var webroot_path=/var/www/melochenator.com/www/html/ (set by user).
2019-01-27 14:24:18,774:DEBUG:certbot.cli:Var webroot_map=set([‘webroot_path’]) (set by user).
2019-01-27 14:24:19,924:DEBUG:certbot.cli:Var webroot_path=/var/www/melochenator.com/www/html/ (set by user).
2019-01-27 14:24:20,780:DEBUG:certbot.cli:Var authenticator=webroot (set by user).
2019-01-27 14:24:22,022:DEBUG:certbot.storage:Writing new config /etc/letsencrypt/renewal/melochenator.com.conf.new.
2019-01-27 14:24:22,024:DEBUG:certbot.reporter:Reporting to user: Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/melochenator.com/fullchain.pem
/etc/letsencrypt/live/melochenator.com/privkey.pem
Your cert will expire on 2019-04-27. To obtain a new or tweaked version of this certificate in the future, simply run certbot-auto again. To non-interactively renew all of your certificates, run “certbot-auto renew”
2019-01-27 14:24:22,024:DEBUG:certbot.reporter:Reporting to user: If you like Certbot, please consider supporting our work by:
Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
what is the thing tell me i am using the right method? sent you the log
This is good.
You are using webroot as authenticator, so you don't use tls-sni-01 - validation.
Thank you so much. i know i am idiot :slight_smile:
