Hi all,
I had certbot running as standalone. Renewals in the past did not cause any problem but this time I'm screwed and have no idea how to handle this.
In the past it was all pretty easy. I have an nginx on my pi. In the past I turned it off for renewals, started certbot and all was good.
I wonder if sudo apt --purge remove certbot, erase /etc/letsencrypt by hand and sudo apt install certbot is a wise thing. As the outdated certificates still work I'd like to have an experienced user have a look ...
Any hints are highly appreciated!
root@pi# certbot --version
certbot 2.1.0
root@pi# netstat -tunlp
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:5232 0.0.0.0:* LISTEN 1752/docker-proxy
tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 32394/cupsd
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 800/sshd: /usr/sbin
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 898/pihole-FTL
tcp 0 0 127.0.0.1:42291 0.0.0.0:* LISTEN 783/containerd
tcp 0 0 0.0.0.0:888 0.0.0.0:* LISTEN 898/pihole-FTL
tcp 0 0 0.0.0.0:5000 0.0.0.0:* LISTEN 1586/docker-proxy
tcp 0 0 127.0.0.1:6011 0.0.0.0:* LISTEN 82406/sshd: pi@pts/
tcp 0 0 127.0.0.1:6010 0.0.0.0:* LISTEN 82358/sshd: pi@pts/
tcp 0 0 127.0.0.1:6012 0.0.0.0:* LISTEN 82431/sshd: pi@pts/
udp 0 0 0.0.0.0:53 0.0.0.0:* 898/pihole-FTL
udp 0 0 0.0.0.0:123 0.0.0.0:* 898/pihole-FTL
udp 0 0 0.0.0.0:5353 0.0.0.0:* 579/avahi-daemon: r
udp 0 0 0.0.0.0:59035 0.0.0.0:* 579/avahi-daemon: r
root@pi# certbot certonly -v -d dav.knowscore.de -d knowscore.de -d knowscore.social -d transl.knowscore.de -d www.knowscore.de -d knowscore.social -d gottteam.social -d hammeln.social -m java@wispa.de --standalone
Requesting a certificate for dav.knowscore.de and 6 more domains
http-01 challenge for dav.knowscore.de
http-01 challenge for gottteam.social
http-01 challenge for hammeln.social
http-01 challenge for knowscore.de
http-01 challenge for knowscore.social
http-01 challenge for transl.knowscore.de
http-01 challenge for www.knowscore.de
Challenge failed for domain dav.knowscore.de
Challenge failed for domain gottteam.social
Challenge failed for domain hammeln.social
Challenge failed for domain knowscore.de
Challenge failed for domain knowscore.social
Challenge failed for domain transl.knowscore.de
Challenge failed for domain www.knowscore.de
Domain: dav.knowscore.de
Type: connection
Detail: 91.10.78.139: Fetching http://dav.knowscore.de/.well-known/acme-challenge/rtcsIZmETfoLIhEpu75SzTVfYpVs47JmtKhO6zOzl-s: Connection refused
Domain: gottteam.social
Type: connection
Detail: 91.10.78.139: Fetching http://gottteam.social/.well-known/acme-challenge/f_U-TCe8hSY61G8rhVpotErAnv28LXwYwRc4y6XEXrs: Connection refused
Domain: hammeln.social
Type: connection
Detail: 91.10.78.139: Fetching http://hammeln.social/.well-known/acme-challenge/iPkX-8eiSJWiYbBJeWT7bhbXo6IC-3qX5yxG5IePurM: Connection refused
Domain: knowscore.de
Type: connection
Detail: 91.10.78.139: Fetching http://knowscore.de/.well-known/acme-challenge/Wrro5L4GUZxwlWqvF5d3-l3b3sPSqqdCKU1qFbq5xM8: Connection refused
Domain: knowscore.social
Type: connection
Detail: 91.10.78.139: Fetching http://knowscore.social/.well-known/acme-challenge/zwwuXkI9IgAp74Ukvvs5PdRXmawLWBRIr-0e_8bDaY8: Connection refused
Domain: transl.knowscore.de
Type: connection
Detail: 91.10.78.139: Fetching http://transl.knowscore.de/.well-known/acme-challenge/TmfsRA3KFeELayeSUIbnxySdvnxpoWPghT42oKqqKFU: Connection refused
Domain: www.knowscore.de
Type: connection
Detail: 91.10.78.139: Fetching http://www.knowscore.de/.well-known/acme-challenge/j8bjw00Vbcc7KfDp3gfVS1tBMTwEVpHyTEjwsa8rauk: Connection refused
root@pi# more /var/log/letsencrypt/letsencrypt.log
2025-03-24 12:24:20,563:DEBUG:certbot._internal.main:certbot version: 2.1.0
2025-03-24 12:24:20,564:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2025-03-24 12:24:20,564:DEBUG:certbot._internal.main:Arguments: ['-v', '-d', 'dav.knowscore.de', '-d', 'knowscore.de', '-d', 'knowscore.social', '-d', 'transl.knowscore.de', '-d', 'www.knowscore.de', '-d', 'knowscore.social', '-d', 'gottteam.social', '-d', 'hammeln.social', '-m', 'java@w
ispa.de', '--standalone']
2025-03-24 12:24:20,565:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2025-03-24 12:24:20,585:DEBUG:certbot._internal.log:Root logging level set at 20
2025-03-24 12:24:20,586:DEBUG:certbot._internal.plugins.selection:Requested authenticator standalone and installer None
2025-03-24 12:24:20,587:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * standalone
Description: Spin up a temporary webserver
Interfaces: Authenticator, Plugin
Entry point: standalone = certbot._internal.plugins.standalone:Authenticator
Initialized: <certbot._internal.plugins.standalone.Authenticator object at 0x7f7b94a510>
Prep: True
2025-03-24 12:24:20,588:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot._internal.plugins.standalone.Authenticator object at 0x7f7b94a510> and installer None
2025-03-24 12:24:20,588:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator standalone, Installer None
2025-03-24 12:24:20,901:DEBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letse
ncrypt.org/acme/acct/1419318876', new_authzr_uri=None, terms_of_service=None), 9d2d0c0fe73246e47855b4f56ee11981, Meta(creation_dt=datetime.datetime(2023, 11, 17, 14, 25, 30, tzinfo=<UTC>), creation_host='pi5', register_to_eff=None))>
2025-03-24 12:24:20,903:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2025-03-24 12:24:20,907:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2025-03-24 12:24:21,457:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 1042
2025-03-24 12:24:21,458:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Mon, 24 Mar 2025 11:24:21 GMT
Content-Length: 1042
X-Frame-Options: DENY
"meta": {
"caaIdentities": [
"letsencrypt.org"
"profiles": {
"classic": "https://letsencrypt.org/docs/profiles#classic",
"shortlived": "https://letsencrypt.org/docs/profiles#shortlived (not yet generally available)",
"tlsserver": "https://letsencrypt.org/docs/profiles#tlsserver (not yet generally available)"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.5-February-24-2025.pdf",
"renewalInfo": "https://acme-v02.api.letsencrypt.org/draft-ietf-acme-ari-03/renewalInfo",
"revokeCert": "https://acme-v02.api.letsencrypt.org/acme/revoke-cert",
"wnV72HSxvbk": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417"
2025-03-24 12:24:21,459:DEBUG:certbot._internal.display.obj:Notifying user: Requesting a certificate for dav.knowscore.de and 6 more domains
2025-03-24 12:24:21,465:DEBUG:certbot.crypto_util:Generating ECDSA key (2048 bits): /etc/letsencrypt/keys/0003_key-certbot.pem
2025-03-24 12:24:21,471:DEBUG:certbot.crypto_util:Creating CSR: /etc/letsencrypt/csr/0003_csr-certbot.pem
2025-03-24 12:24:21,474:DEBUG:acme.client:Requesting fresh nonce
2025-03-24 12:24:21,474:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2025-03-24 12:24:21,657:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2025-03-24 12:24:21,657:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
root@pi# cat /var/log/letsencrypt/letsencrypt.log
2025-03-24 12:24:27,647:DEBUG:certbot._internal.error_handler:Encountered exception:
File "/usr/lib/python3/dist-packages/certbot/_internal/auth_handler.py", line 106, in handle_authorizations
File "/usr/lib/python3/dist-packages/certbot/_internal/auth_handler.py", line 206, in _poll_authorizations
2025-03-24 12:24:27,648:DEBUG:certbot._internal.error_handler:Calling registered functions
2025-03-24 12:24:27,648:INFO:certbot._internal.auth_handler:Cleaning up challenges
2025-03-24 12:24:27,654:DEBUG:certbot._internal.plugins.standalone:Stopping server at 0.0.0.0:80...
2025-03-24 12:24:28,070:DEBUG:certbot._internal.log:Exiting abnormally:
File "/usr/bin/certbot", line 33, in <module>
sys.exit(load_entry_point('certbot==2.1.0', 'console_scripts', 'certbot')())
File "/usr/lib/python3/dist-packages/certbot/main.py", line 19, in main
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1736, in main
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1590, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 138, in _get_and_save_cert
File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 516, in obtain_and_enroll_certificate
File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 428, in obtain_certificate
File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 496, in _get_order_and_authorizations
2025-03-24 12:24:28,080:ERROR:certbot._internal.log:Some challenges have failed.
