nginx version: nginx/1.16.1
Centos7
self
no
certbot 1.13.0
Hello!
I'm trying to set HTTPS for my site, and I have followed the instructions I have found linked from the Let'sEncrypt home page:
I have installed snapd, certbot and created the certificates, and all steps were successful. But then, the HTTPS access to my test site always returns a "connection refused" error.
Here below, you can find all the outputs from my attempts and tests.
Thanks a lot for your kind help, and I wish you a very good day and a nice Easter weekend!
Regards,
-- Riccardo.
certificates
# sudo certbot --nginx
1: ricercatoritaliani.ch
2: www.ricercatoritaliani.ch
blank to select all options shown (Enter 'c' to cancel): 1,2
Requesting a certificate for ricercatoritaliani.ch and www.ricercatoritaliani.ch
Deploying Certificate to VirtualHost /etc/nginx/nginx.conf
Redirecting all traffic on port 80 to ssl in /etc/nginx/nginx.conf
Congratulations! You have successfully enabled https://ricercatoritaliani.ch and
https://www.ricercatoritaliani.ch
/etc/letsencrypt/live/ricercatoritaliani.ch/fullchain.pem
/etc/letsencrypt/live/ricercatoritaliani.ch/privkey.pem
Your certificate will expire on 2021-07-01. To obtain a new or
tweaked version of this certificate in the future, simply run
certbot again with the "certonly" option. To non-interactively
renew *all* of your certificates, run "certbot renew"
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
renewal test
# sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/ricercatoritaliani.ch.conf
Simulating renewal of an existing certificate for ricercatoritaliani.ch and www.ricercatoritaliani.ch
http-01 challenge for ricercatoritaliani.ch
http-01 challenge for www.ricercatoritaliani.ch
new certificate deployed with reload of nginx server; fullchain is
Congratulations, all simulated renewals succeeded:
/etc/letsencrypt/live/ricercatoritaliani.ch/fullchain.pem (success)
cleared nginx cache
# cd /var/run/nginx-cache/
# rm -rf ./*
restarted nginx
# sudo systemctl stop nginx
# sudo systemctl start nginx
80: OK - 443: "connection refused" error
If I access my test site through HTTPS in web browser, I get a "connection refused" error.
If I disable 443 and enable 80, and I access my test site through a web browser on HTTP, everything works fine.
failed test on SSLabs
https://www.ssllabs.com/ssltest/analyze.html?d=www.ricercatoritaliani.ch&latest
SSlabs returns: Assessment failed: Unable to connect to the server
Curl tests
If I test curl from my server, the one I'm trying to fix, all seems OK:
# curl --verbose https://www.ricercatoritaliani.ch
* About to connect() to www.ricercatoritaliani.ch port 443 (#0)
* Trying 31.14.131.121...
* Connected to www.ricercatoritaliani.ch (31.14.131.121) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* SSL connection using TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
* Server certificate:
* subject: CN=ricercatoritaliani.ch
* start date: Apr 02 08:21:19 2021 GMT
* expire date: Jul 01 08:21:19 2021 GMT
* common name: ricercatoritaliani.ch
* issuer: CN=R3,O=Let's Encrypt,C=US
> GET / HTTP/1.1
> User-Agent: curl/7.29.0
> Host: www.ricercatoritaliani.ch
> Accept: */*
< HTTP/1.1 200 OK
< Server: nginx/1.16.1
< Date: Fri, 02 Apr 2021 09:26:19 GMT
< Content-Type: text/html; charset=UTF-8
< Transfer-Encoding: chunked
< Connection: keep-alive
< Vary: Accept-Encoding
< X-Powered-By: PHP/7.3.14
<!doctype html>
<html>
<head>
<title>This is the title of the webpage!</title>
</head>
<body>
<p>This is an example paragraph. Anything in the <strong>body</strong> tag will appear on the page, just like this <strong>p</strong> tag and its contents.</p>
</body>
</html>
* Connection #0 to host www.ricercatoritaliani.ch left intact
However, if I use curl from another machine, then the connection is refused:
* Rebuilt URL to: https://www.ricercatoritaliani.ch/
* TCP_NODELAY set
* Connection failed
* connect to 31.14.131.121 port 443 failed: Connection refused
* Failed to connect to www.ricercatoritaliani.ch port 443: Connection refused
* Closing connection 0
curl: (7) Failed to connect to www.ricercatoritaliani.ch port 443: Connection refused
While using curl on HTTP, I see the redirection automatically set by Certbot (but then https does not work):
curl --verbose http://www.ricercatoritaliani.ch
* Rebuilt URL to: http://www.ricercatoritaliani.ch/
* TCP_NODELAY set
* Connected to www.ricercatoritaliani.ch (31.14.131.121) port 80 (#0)
> GET / HTTP/1.1
> User-Agent: curl/7.54.0
> Accept: */*
< HTTP/1.1 301 Moved Permanently
< Date: Fri, 02 Apr 2021 09:28:37 GMT
< Content-Length: 169
< Location: https://www.ricercatoritaliani.ch/
<html>
<head><title>301 Moved Permanently</title></head>
<body>
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx/1.16.1</center>
</body>
</html>
Nginx conf --modified by Certbot--
This is the nginx conf file automatically modified by Certbot:
For more information on configuration, see:
# * Official English Documentation: http://nginx.org/en/docs/
# * Official Russian Documentation: http://nginx.org/ru/docs/
user nginx;
worker_processes auto;
pid /run/nginx.pid;
# Load dynamic modules. See /usr/share/doc/nginx/README.dynamic.
include /usr/share/nginx/modules/*.conf;
events {
worker_connections 1024;
http {
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# Load modular configuration files from the /etc/nginx/conf.d directory.
# See http://nginx.org/en/docs/ngx_core_module.html#include
# for more information.
fastcgi_cache_path /var/run/nginx-cache levels=1:2 keys_zone=WORDPRESS:100m inactive=60m;
fastcgi_cache_key "$scheme$request_method$host$request_uri";
root /var/www/html;
index index.php;
server_name ricercatoritaliani.ch www.ricercatoritaliani.ch;
#server_name www.ricercatoritaliani.ch;
### enable gzip
gzip on;
gzip_disable "MSIE [1-6]\.(?!.*SV1)";
gzip_vary on;
gzip_types text/plain text/css text/javascript image/svg+xml image/x-icon application/javascript application/x-javascript;
# log files
access_log /var/log/nginx/wordpress.access.log;
error_log /var/log/nginx/wordpress.error.log;
set $skip_cache 0;
# POST requests and URLs with a query string should always go to PHP
if ($request_method = POST) {
set $skip_cache 1;
if ($query_string != "") {
set $skip_cache 1;
# Don't cache URIs containing the following segments
if ($request_uri ~* "/wp-admin/|/xmlrpc.php|wp-.*.php|/feed/|index.php|sitemap(_index)?.xml") {
set $skip_cache 1;
# Don't use the cache for logged-in users or recent commenters
if ($http_cookie ~* "comment_author|wordpress_[a-f0-9]+|wp-postpass|wordpress_no_cache|wordpress_logged_in") {
set $skip_cache 1;
try_files $uri $uri/ /index.php?$args;
location ~ .php$ {
#try_files $uri /index.php;
try_files $uri =404;
include fastcgi_params;
fastcgi_pass unix:/var/run/php-fpm/php-fpm.sock;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_cache_bypass $skip_cache;
fastcgi_no_cache $skip_cache;
fastcgi_cache WORDPRESS;
fastcgi_cache_valid 60m;
location ~* ^.+.(ogg|ogv|svg|svgz|eot|otf|woff|mp4|ttf|css|rss|atom|js|jpg|jpeg|gif|png|ico|zip|tgz|gz|rar|bz2|doc|xls|exe|ppt|tar|mid|midi|wav|bmp|rtf)$ {
access_log off;
log_not_found off;
expires max;
location = /robots.txt {
access_log off;
log_not_found off;
#location ~ /. {
# deny all;
# access_log off;
# log_not_found off;
ssl_certificate /etc/letsencrypt/live/ricercatoritaliani.ch/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/ricercatoritaliani.ch/privkey.pem; # managed by Certbot
if ($host = www.ricercatoritaliani.ch) {
} # managed by Certbot
if ($host = ricercatoritaliani.ch) {
listen 80;
