How to create wildcard ssl using letsencrypt
hello all,
i have windows 2012 r2 with IIS.
i have one main domain called www.MyDomain.com and some sub domains they are one.MyDomain.com
two.MyDomain.com
three.MyDomain.com
i have downloaded acme.exe tool using that If i create SSL for MyDomain.com then it works but, when I start create SSL for one.MyDomain.com then MyDomain.com is not working since, the port# is overwrite.
then i tried to create ssl using "Full Options" and targetted site as MyDomain.com and it start work then if i add the same SSL for one.MyDomain.com there its not working.
someone please guide me, how to create WildCard SSL?
thanks
jey
To me, it doesn't sound like a wildcard cert, nor any cert, will fix this problem.
I think the IIS configuration may need to be corrected to work with multiple sites first.
