Hello community, I am trying to setup LE on RaspBi running pi-hole.
I've used certbot to grab the files.
Had a few issues with A records and then permissions (think I was runnning the wrong command.)
Anyway I've now got the certs generated but my lighttpd service wont start when I have my external.conf file in the /etc/lighttpd/ folder
pihole.knobheads.xyz
certbot certonly --webroot -w /var/www/html -d pihole.knobheads.xyz -d www.pihole.knobheads.xyz
http-01 challenge for pihole.knobheads.xyz
http-01 challenge for www.pihole.knobheads.xyz
Using the webroot path /var/www/html for all unmatched domains.
/etc/letsencrypt/live/pihole.knobheads.xyz/fullchain.pem
/etc/letsencrypt/live/pihole.knobheads.xyz/privkey.pem
Your cert will expire on 2022-09-11. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew *all* of your certificates, run
"certbot renew"
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
pi@pi-hole:~ $ lighttpd -v
lighttpd/1.4.45 (ssl) - a light and fast webserver
Build-Date: Jan 14 2017 21:07:19
pi@pi-hole:~ $ uname -a
Linux pi-hole 4.14.69-v7+ #1141 SMP Mon Sep 10 15:26:29 BST 2018 armv7l GNU/Linux
NA
Yes
no
pi@pi-hole:~ $ certbot --version
certbot 0.28.0
I am trying to get SSL installed on my Raspberry Pi running Pi-Hole.
Ive got the certs generated but something has happened to my external.conf file that seems to stop lighttpd from running.
Here is is the contents of external.conf
$HTTP["host"] == "pihole.knobheads.xyz" {
# Ensure the Pi-hole Block Page knows that this is not a blocked domain
setenv.add-environment = ("fqdn" => "true")
# Enable the SSL engine with a LE cert, only for this specific host
$SERVER["socket"] == ":443" {
ssl.engine = "enable"
ssl.pemfile = "/etc/letsencrypt/live/pihole.knobheads.xyz/conf.pem"
ssl.ca-file = "/etc/letsencrypt/live/pihole.knobheads.xyz/intermediate.pem"
ssl.honor-cipher-order = "enable"
ssl.cipher-list = "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH"
ssl.use-compression = "disable"
ssl.use-sslv2 = "disable"
ssl.use-sslv3 = "disable"
# Redirect HTTP to HTTPS
$HTTP["scheme"] == "http" {
$HTTP["host"] =~ ".*" {
url.redirect = (".*" => "https://%0$0")
I followed this guide:
I modified the path to the pem files as they where originally pointing to /home/pi/
If I rename my external.conf to external.conf.bak then lighttpd will run.
Can some kind soul please help get this working?
