i just intalled certbot on my rpi with raspian.
When i try to get a cert certbot doenst do anything…
I already tried to just get the latest version from GitHub -> Same behavior
Getting it from testing repo -> Same behavior
Getting it from backports repo -> Same behavior
@Mike1082 dont think that my problem is issued by this service disruption.
In this case certbot should say couldnt connect or nah? Already had this problem on a different device some time ago…
Try checking your log files. Not sure if the location will be the same on the Pi (I am running in Docker) but for me it was /var/log/letsencrypt. I ran:
# tail -f /var/log/letsencrypt/letsencrypt.log
The output showed I was getting a ClientError: <Response 504> when trying to contact acme-v01.api.letsencrypt.org (which is related to the current outage).
Tried again. Which plugin is meant in the following… 2017-05-20 14:21:21,401:DEBUG:certbot.main:Root logging level set at 20 2017-05-20 14:21:21,432:INFO:certbot.main:Saving debug log to /var/log/letsencrypt/letsencrypt.log 2017-05-20 14:21:21,461:DEBUG:certbot.main:certbot version: 0.10.2 2017-05-20 14:21:21,464:DEBUG:certbot.main:Arguments: ['--apache', '-d', 'domain.de', '-d', 'sub.domain.de', '-d', 'sub.domain.de', '-d', 'sub.domain.de'] 2017-05-20 14:21:21,490:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#webroot,PluginEntryPoint#null,PluginEntryPoint#manual,PluginEntryPoint#standalone) 2017-05-20 14:21:21,502:DEBUG:certbot.plugins.selection:Requested authenticator apache and installer apache 2017-05-20 14:21:21,506:DEBUG:certbot.plugins.selection:No candidate plugin 2017-05-20 14:21:21,509:DEBUG:certbot.plugins.selection:No candidate plugin 2017-05-20 14:21:21,512:DEBUG:certbot.plugins.selection:Selected authenticator None and installer None 2017-05-20 14:21:21,515:INFO:certbot.main:Could not choose appropriate plugin: The requested apache plugin does not appear to be installed 2017-05-20 14:21:21,559:DEBUG:certbot.main:Exiting abnormally: Traceback (most recent call last): File "/usr/bin/certbot", line 11, in <module> load_entry_point('certbot==0.10.2', 'console_scripts', 'certbot')() File "/usr/lib/python2.7/dist-packages/certbot/main.py", line 849, in main return config.func(config, plugins) File "/usr/lib/python2.7/dist-packages/certbot/main.py", line 617, in obtain_cert installer, auth = plug_sel.choose_configurator_plugins(config, plugins, "certonly") File "/usr/lib/python2.7/dist-packages/certbot/plugins/selection.py", line 197, in choose_configurator_plugins diagnose_configurator_problem("authenticator", req_auth, plugins) File "/usr/lib/python2.7/dist-packages/certbot/plugins/selection.py", line 272, in diagnose_configurator_problem raise errors.PluginSelectionError(msg) PluginSelectionError: The requested apache plugin does not appear to be installed
Yes but want to know how the name of the plugin is. I know that something with Apache doesn’t work but the logs don’t help my finding out the name of the required plugin.
The packages that you need are augeas-lenses and libaugeas0 but they should be installed automatically if you are using the last certbot version (0.14.1)… at least on Raspberry Pi 3 and raspbian-Jessie that is what I’m using ( it could work fine in Raspberry Pi 2 but I don’t have one to test it)
So, first remove the virtualenv and install certbot-auto as root.
certbot-auto will try to install all the needed packages (it could take several minutes).
Just in case you want to compare, these are my sources:
root@miniwinipoint:~# grep -i '^[a-z]' /etc/apt/sources.list
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
root@miniwinipoint:~# grep -i '^[a-z]' /etc/apt/sources.list.d/raspi.list
deb http://archive.raspberrypi.org/debian/ jessie main ui
Edit: These are the versions of main packages that certbot-auto will try to install.
# dpkg -l | grep -E '(augeas-lenses |ca-certificates |gcc |libaugeas0 |libffi-dev |libssl-dev |openssl |ii python |python-dev |python-virtualenv |virtualenv )'
ii augeas-lenses 1.2.0-0.2+deb8u1 all Set of lenses needed by libaugeas0 to parse config files
ii ca-certificates 20141019+deb8u3 all Common CA certificates
ii gcc 4:4.9.2-2 armhf GNU C compiler
ii libaugeas0 1.2.0-0.2+deb8u1 armhf Augeas configuration editing library and API
ii openssl 1.0.1t-1+deb8u6 armhf Secure Sockets Layer toolkit - cryptographic utility
ii python 2.7.9-1 armhf interactive high-level object-oriented language (default version)
ii python-dev 2.7.9-1 armhf header files and a static library for Python (default)
ii python-virtualenv 1.11.6+ds-1 all Python virtual environment creator
ii python3-virtualenv 1.11.6+ds-1 all Python virtual environment creator
ii virtualenv 1.11.6+ds-1 all Python virtual environment creator
