Help me reset my domain limit
My domains are foreverworld.org and admin.foreverworld.org. I have reached weekly limit. Is it possible to reset the limit for these domains? Thanks.
Nope!
The only rate limit you're currently affected by is the ability to issue a certificate that has only the name of: foreverworld.org .
It is the Duplicate Certificate Limit as documented on this page: Rate Limits - Let's Encrypt
That page also talks about how you may be able to work around it. For example, by issuing a certificate with both admin.foreverworld.org and foreverworld.org on it.
