Hello I were running the following on on my ubuntu server
sudo letsencrypt --apache -d example.com -d www.example.com
example.com replaced for my own domain of course, how ever i accidently exited out the automated installer and ended up with the following message
Failed authorization procedure. example.com (tls-sni-01): urn:acme:error:tls :: The server experienced a TLS error during domain verification :: Failed to connect to 104.27.180.219:443 for TLS-SNI-01 challenge
Domain: example.com
Type: tls
Detail: Failed to connect to 104.27.180.219:443 for TLS-SNI-01
challengeTo fix these errors, please make sure that your domain name was
you have an up-to-date TLS configuration that allows the server to
communicate with the Let's Encrypt client.
How can i fix this now, where are the files and steps to configure this manually?
