Good morrning
run the following command
sudo ./letsencrypt-auto -d example.com auth
Domains: example.com
Error: The server could not connect to the client for DV
To fix these errors, please make sure that your domain name was entered correctly and the DNS A record(s) for that domain contain(s) the right IP address. Additionally, please check that your computer has a publicly routable IP address and that no firewalls are preventing the server from communicating with the client.
2015-11-17 17:55:05,412:INFO:letsencrypt.auth_handler:Cleaning up challenges
2015-11-17 17:55:05,412:DEBUG:letsencrypt.plugins.standalone:Stopping server at 0.0.0.0:443…
2015-11-17 17:55:05,531:DEBUG:letsencrypt.cli:Exiting abnormally:
File “/root/.local/share/letsencrypt/bin/letsencrypt”, line 11, in
sys.exit(main())
File “/root/.local/share/letsencrypt/lib/python2.7/site-packages/letsencrypt/cli.py”, line 1187, in main
return args.func(args, config, plugins)
File “/root/.local/share/letsencrypt/lib/python2.7/site-packages/letsencrypt/cli.py”, line 497, in obtain_cert
_auth_from_domains(le_client, config, domains)
File “/root/.local/share/letsencrypt/lib/python2.7/site-packages/letsencrypt/cli.py”, line 326, in _auth_from_domains
lineage = le_client.obtain_and_enroll_certificate(domains)
File “/root/.local/share/letsencrypt/lib/python2.7/site-packages/letsencrypt/client.py”, line 254, in obtain_and_enroll_certificate
certr, chain, key, _ = self.obtain_certificate(domains)
File “/root/.local/share/letsencrypt/lib/python2.7/site-packages/letsencrypt/client.py”, line 237, in obtain_certificate
return self._obtain_certificate(domains, csr) + (key, csr)
File “/root/.local/share/letsencrypt/lib/python2.7/site-packages/letsencrypt/client.py”, line 195, in _obtain_certificate
authzr = self.auth_handler.get_authorizations(domains)
File “/root/.local/share/letsencrypt/lib/python2.7/site-packages/letsencrypt/auth_handler.py”, line 84, in get_authorizations
self._respond(cont_resp, dv_resp, best_effort)
File “/root/.local/share/letsencrypt/lib/python2.7/site-packages/letsencrypt/auth_handler.py”, line 142, in _respond
self._poll_challenges(chall_update, best_effort)
File “/root/.local/share/letsencrypt/lib/python2.7/site-packages/letsencrypt/auth_handler.py”, line 204, in _poll_challenges
raise errors.FailedChallenges(all_failed_achalls)
FailedChallenges: Failed authorization procedure. example.com (http-01): connection :: The server could not connect to the client for DV :: Could not connect to http://example.com/.well-known/acme-challenge/Eot26qQbyBt1HreLPxEypL4JRpJzLJUU50Aod3EmpQQ
port 443 and 80 are enabled,
the host this public
Any ideas why I make this mistake.
I want to use the certificate for a JBoss application server
correct this command I’m using?
Thank you for your help
