Failed authorization procedure _ Please help
My domain is: my.example.com
I ran this command: ./letsencrypt-auto --apache -d my.example.com
root@VM-MEngine:/opt/letsencrypt# ./letsencrypt-auto --apache -d my.example.com
tls-sni-01 challenge for my.example.com
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Waiting for verification…
Failed authorization procedure. my.example.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout
    Domain: my.example.com
    Type: connection
    Detail: Timeout
My web server is (include version): apache2
The operating system my web server runs on is (include version): Ubuntu 14.04.5
Do you have port 443 open in your firewall or properly opened/port mapped in case of a NAT router?
443 port was not open. After opening the port, issue got resolved.
Thanks a lot for your help Osiris.
