Hi everybody! When I run this:
./letsencrypt-auto --apache -d example.com
then
`Checking for new version…
Requesting root privileges to run letsencrypt…
sudo /home/duchoan/.local/share/letsencrypt/bin/letsencrypt --apache -d example.com
Failed authorization procedure. example.com (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Correct zName not found for TLS SNI challenge. Found …
Domain: example.com
Detail: Correct zName not found for TLS SNI challenge. Found
ww.example.org, example.com, example.edu, example.net,
example.org, ww.example.com, ww.example.edu, ww.example.netTo fix these errors, please make sure that your domain name was
contain(s) the right IP address.`
Can anybody help me fix this error? Thank you!
