Hi everyone,
I’m facing an issue with differents linux distributions. I’d like to install letsencrypt in the domaine webinti.ovh.
I have a Debian 8 VPS with ISP CONFIG and apache2 i followed this tutorial : https://www.howtoforge.com/tutorial/perfect-server-debian-8-jessie-apache-bind-dovecot-ispconfig-3/1/.
So in /etc/root i cloned the Github repo and launched it with ./letsencrypt-auto. It recognized my domain so I clicked OK and accepted the agreements.
And after I had this issue :
Failed authorization procedure. www. webinti.ovh (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Correct zName not found for TLS SNI challenge. Found ‘mailconfig.ovh.net’
Domain: www. webinti.ovh
Type: urn:acme:error:unauthorized
Detail: Correct zName not found for TLS SNI challenge. Found
’mailconfig.ovh.net’
When i enter this command :->
./letsencrypt-auto certonly --standalone -d webinti.ovh -d www.webinti.ovh
IT SAYS:
- Congratulations! Your certificate and chain have been saved at
/etc/letsencrypt/live/webinti.ovh/fullchain.pem. Your cert will
expire on 2016-05-02. To obtain a new version of the certificate in
the future, simply run Let’s Encrypt again.
When i visit my website with https it doesnt work.
Can you please help me to find out what i’ve missed
Thanks
Tim
