the new one which I can't generate the certificate for -> nfe.penselaranja.com.br
All others work well, including other cnames (www, dev, assinaturas).penselaranja.combr
1: eider.blog.br
2: www.eider.blog.br
3: eider.com.br
4: www.eider.com.br
5: eideroliveira.com.br
6: www.eideroliveira.com.br
7: penselaranja.com.br
8: assinaturas.penselaranja.com.br
9: dev.penselaranja.com.br
10: nfe.penselaranja.com.br
11: www.penselaranja.com.br
12: eider.photography
13: www.eider.photography
14: eideroliveira.com
15: www.eideroliveira.com
certbot
Domain: nfe.penselaranja.com.br
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for nfe.penselaranja.com.br - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for nfe.penselaranja.com.br - check that a DNS record exists for this domain
$ /usr/sbin/apache2 -v
Server version: Apache/2.4.52 (Ubuntu)
Server built: 2022-09-30T04:09:50
My hosting provider, if applicable, is: self hosted
or certbot-auto --version
if you're using Certbot):
$ certbot --version
certbot 1.21.0
eider@website:/etc/apache2$ dig nfe.penselaranja.com.br
; <<>> DiG 9.18.1-1ubuntu1.2-Ubuntu <<>> nfe.penselaranja.com.br
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 50933
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 65494
;; QUESTION SECTION:
;nfe.penselaranja.com.br. IN A
;; ANSWER SECTION:
nfe.penselaranja.com.br. 3600 IN CNAME pensealaranja.com.br.
;; AUTHORITY SECTION:
com.br. 900 IN SOA a.dns.br. hostmaster.registro.br. 2023084422 1800 900 604800 900
;; Query time: 680 msec
;; SERVER: 127.0.0.53#53(127.0.0.53) (UDP)
;; WHEN: Sat Mar 25 10:36:19 PDT 2023
;; MSG SIZE rcvd: 142
