My domain is:faportal-usa.com
I ran this command:sudo certbot --apache
Failed authorization procedure. faportal-usa.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://faportal-usa.com/.well-known/acme-challenge/lAdM1zczLg1Z9MV5K4MLDIHWZ9Dz9r3uQfOiOTSa5-k: Timeout during connect (likely firewall problem), portal-finchautomation-indiana.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://portal-finchautomation-indiana.com/.well-known/acme-challenge/3DzEv7dkmJyKKtUL0QtfcE0nLZM-axEY2DJZoSKLn3I: Timeout during connect (likely firewall problem), www.portal-finchautomation-indiana.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.portal-finchautomation-indiana.com/.well-known/acme-challenge/SeeIGdWOy1xpQafZC9cTOPWVjNGHxAyDVrRBh0KgEyk: Timeout during connect (likely firewall problem), www.faportal-usa.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.faportal-usa.com/.well-known/acme-challenge/1I8wxnl7VWQz8J2c00YJ_z6xrnmwDXh6EKIDFmoPkw4: Timeout during connect (likely firewall problem)
Domain: faportal-usa.com
Type: connection
Detail: Fetching
Timeout during connect (likely firewall problem)Domain: portal-finchautomation-indiana.com
Type: connection
Detail: Fetching
Timeout during connect (likely firewall problem)Domain: www.portal-finchautomation-indiana.com
Type: connection
Detail: Fetching
Timeout during connect (likely firewall problem)Domain: www.faportal-usa.com
Type: connection
Detail: Fetching
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
The operating system my web server runs on is (include version):Ubuntu 18.04.4 LTS
