My domain is: rahma.dyndns.org
I ran this command: sudo ./letsencrypt-auto --apache -d rahma.dyndns.org
http-01 challenge for rahma.dyndns.org
Failed authorization procedure. rahma.dyndns.org (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://rahma.dyndns.org/.well-known/acme-challenge/glRoScTSYCTLDnyar9lHVR5US7vrTC8lay8GPhPJ_PA: Timeout during connect (likely firewall problem)
Domain: rahma.dyndns.org
Type: connection
Detail: Fetching
My web server is (include version): apache2 v. 2.4.18-2ubuntu3.8
The operating system my web server runs on is (include version): Ubuntu 16.04 (64-bit)
My hosting provider, if applicable, is: self
This appears similar to other previous posts, but I’ve reviewed them and I think this is a different problem.
Basically, I’m seeing no evidence in apache logs that the attempt to authorize hits my server at all. However, I am able to get to a test file in the webroot folder on the server via both ports 80 and 443.
The external connection goes thru an ISP modem to an internal router to the server. Both of these ports are open on both devices and ISP directs to router which directs to server. And, this works in a browser to pull up web pages on the server from outside on both ports.
Firewalls are deactivated on both devices.
Why can I serve web pages to the internet on both ports, but the authorization command cannot get thru to the server?
Help and Thanks
Hi @fstriley,
Are you sure?. I can't connect to your server using port 80:
$ curl -IkL -m20 http://rahma.dyndns.org/test
curl: (28) Connection timed out after 20000 milliseconds
But I can using port 443:
$ curl -IkL -m20 http://rahma.dyndns.org:443/test
HTTP/1.1 404 Not Found
Date: Thu, 03 May 2018 14:30:28 GMT
Server: Apache/2.4.18 (Ubuntu)
Maybe you are not blocking port 80 but your ISP does.
Cheers,
sahsanu
Hi sahsanu, Actually, yes, I’m also now unable to connect from outside on 80. Could be ISP. I’ll investigate further. Cheers.
Sahsanu, et al. My ISP is, in fact, blocking inbound port 80 and per my discussion with them, they will not unblock it unless I buy the company
I am not that rich.
Does anyone have suggestions about how to create authorization certificate without port 80 open? (Port 443 is open and working)
Thanks.
Port 443 validations are no longer supported.
So, you can use the DNS-01 method instead if you can create TXT records for your domain with a DNS provider API.
Thanks schoen. Unfortunately we are not able to create TXT records as the domain is a dynamic DNS. That in itself is a problem apparently. We’ll rethink our strategy.
Thanks for the help.
Hi @fstriley,
If you don't mind to change the domain there are alternatives.
You can buy a cheap domain or get a free domain at http://www.freenom.com and use a dns provider like Cloudflare, it is free and has an API to update/create/delete DNS records and also allows to update records using ddclient to modify the records for your domain with your dynamic ip address.
If you don't like that idea, you can also use another free dynamic DNS provider that supports adding TXT records (needed for dns challenge) like https://www.dynu.com/. A few days ago I wrote a post with several steps to use this DDNS provider and acme.sh client.
These are the steps to use dynu.com:
1.- Create a free account on dynu.com.
2.- Create a Dynamic DNS Service on dynu.com. Here you add your subdomain and choose the base domain (there are a few to choose, in this example I will use mydyndomain as subdomain and dynu.net as base domain)
3.- Once the domain is created, go to Control Panel -> API Credentials and click on button Reset Credentials, now take note of Client ID and Secret (we will use them later).
4.- Here you could install their dynamic client so it will update your dynamic address or use wget, etc. more info here IP Update Client | Free Dynamic DNS Service | Dynu
5.- Install acme.sh client (more info in https://acme.sh)
curl https://get.acme.sh | sh
6.- Once installed, issue the cert for your domain. Here we will export 2 variables containing the previously created Client ID and Secret (obvously you need to replace the content of these variables with the real data):
export Dynu_ClientId="xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"
export Dynu_Secret="yyyyyyyyyyyyyyyyyyyyyyyyy"
acme.sh --issue --dns dns_dynu -d mydyndomain.dynu.net
And if all work as expected, you get your certificate.
Good luck,
sahsanu
