Failed authorization procedure. during connect (likely firewall problem)
My domain is: hebbq.tdhttt.org
I ran this command: sudo certbot --nginx -d hebbq.tdhttt.org
http-01 challenge for hebbq.tdhttt.org
Waiting for verification…
Failed authorization procedure. hebbq.tdhttt.org (http-01): urn:ietf:params:acme:error:connection :: The server could
not connect to the client to verify the domain :: Fetching http://hebbq.tdhttt.org/.well-known/acme-challenge/1wkOt6sD
yGB8JeNwkJ113KjshMd2V14Jhb9LzxpvA9k: Timeout during connect (likely firewall problem)
    Domain: hebbq.tdhttt.org
    Type: connection
    Detail: Fetching
    http://hebbq.tdhttt.org/.well-known/acme-challenge/1wkOt6sDyGB8JeNwkJ113KjshMd2V14Jhb9LzxpvA9k:
The operating system my web server runs on is (include version): nginx version: nginx/1.14.0 (Ubuntu)
My hosting provider, if applicable, is: self-hosted
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
I am using google domain and home server. I could http my server. Also, I have allowed Nginx Full in ufw.
$ sudo ufw status verbose
output:
Status: active
Logging: on (low)
Default: deny (incoming), allow (outgoing), deny (routed)
New profiles: skip
To Action From
80,443/tcp (Nginx Full) ALLOW IN Anywhere
80/tcp ALLOW IN Anywhere
80,443/tcp (Nginx Full (v6)) ALLOW IN Anywhere (v6)
80/tcp (v6) ALLOW IN Anywhere (v6)
I have searched for similar issues but most of them are hosted on cloud.
It looks like there is no webserver listening on port 80 on your server, check with sudo ss -tlpn -HO
% nmap hebbq.tdhttt.org
Starting Nmap 7.80 ( https://nmap.org ) at 2020-04-03 10:26 CEST
Nmap scan report for hebbq.tdhttt.org (70.187.169.159)
Host is up (0.19s latency).
rDNS record for 70.187.169.159: ip70-187-169-159.oc.oc.cox.net
Not shown: 999 filtered ports
PORT    STATE  SERVICE
443/tcp closed https
Nmap done: 1 IP address (1 host up) scanned in 13.65 seconds
It can also be your ISP blocking port 80.
Thanks for your reply!
I also tried this on another computer same lan. It seems that port 80 shows up (might be I am under the same lan or maybe same ISP?)
Anyways, what should I do if I still want to proceed with certbot? How should I change/forward port 80 for cerbot?
Thanks!
port 80 on your public ip should go to port 80 on the machine running your webserver/certbot.
Hi @TDHTTTT
there is no answer. See https://check-your-website.server-daten.de/?q=hebbq.tdhttt.org
http://hebbq.tdhttt.org/ 70.187.169.159 -14 10.033 T
Timeout - The operation has timed out
https://hebbq.tdhttt.org/ 70.187.169.159 -2 1.544 V
ConnectFailure - Unable to connect to the remote server
http://hebbq.tdhttt.org/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 70.187.169.159 -14 10.053 T
Your port 443 is blocked via a firewall. Your port 80 doesn't answer. A working port 80 is required to use http validation.
Thanks guys. I was able to use acme.sh to get certificates over port 443.
