Failed authorization procedure
My domain is: lora.saluton.dk
I ran this command: sudo certbot --nginx -d lora.saluton.dk
http-01 challenge for lora.saluton.dk
Failed authorization procedure. lora.saluton.dk (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://lora.saluton.dk/.well-known/acme-challenge/uypzdOXrZgdvLe2wnmTmtAslO6-v0D9LmXDFfE87Lwg: Timeout during connect (likely firewall problem)
    Domain: lora.saluton.dk
    Type: connection
    Detail: Fetching
My web server is (include version): nginx/1.14.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 18.04.2 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.31.0
Hi @dtu
there are older checks of your domain - https://check-your-website.server-daten.de/?q=lora.saluton.dk
Only timeouts:
130.225.170.207 -14 10.026 T
Timeout - The operation has timed out
https://lora.saluton.dk/
130.225.170.207 -14 10.010 T
http://lora.saluton.dk/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
130.225.170.207 -14 10.027 T
Visible Content:
There is no older certificate. If you use http-01 validation, a working http website (port 80) is required.
Is there a website? Or is it a firewall / router problem?
Same result checking your ip address ( https://check-your-website.server-daten.de/?q=130.225.170.207 ):
http://130.225.170.207/
130.225.170.207 -14 10.030 T
https://130.225.170.207/
http://130.225.170.207/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
Visible Content:
Thanks for the fast response!
Can this have anything to do with that it’s the web-interface in fact is accessed by “lora.saluton.dk:8080”?
I’ve configured nginx.conf, so that it’s redirecting “lora.saluton.dk”.
/etc/nginx/nginx.conf
    index index.html index.html index.nginx-debian.html;
    server_name lora.saluton.dk; # managed by Certbot
    listen 80;
    proxy_set_header   X-Forwarded-For $remote_addr;
    proxy_set_header   Host $http_host;
    proxy_pass         "http://130.225.170.207:8080";
    location ~ ^/api/(gateways|devices)/(\w+)/(frames|events)$ {
    proxy_pass https://130.225.170.207:8080/api/$1/$2/$3;
    proxy_http_version 1.1;
    proxy_set_header Connection "Upgrade";
    proxy_read_timeout 86400s;
    proxy_send_timeout 86400s;
    #ssl_certificate /etc/loraserver-certificates/certs/keys/cert.pem; # managed by Certbot
    #ssl_certificate_key /etc/loraserver-certificates/certs/keys/key.pem; # managed by Certbot
Does that work internal? External, I see only timeouts.
Is it a home server?
Some ISP are blocking port 80.
