Help certbot my domain
t3m.com.br
sudo certbot --nginx certonly -d pabx.t3m.com.br
Selected plugins: Authenticator nginx, Installer nginx
http-01 challenge for pabx.t3m.com.br
Waiting for verification ...
Failed authorization procedure. pabx.t3m.com.br (http-01): urn: ietf: params: acme: error: connection :: The server could not connect to the client to verify the domain :: Fetching http://pabx.t3m.com .br / .well-known / acme-challenge / HTS2FA37WQVY93tXPAN4FLbz5UsJBOphkUwmSX9Bn3w: Timeout during connect (likely firewall problem)
    I tested another domain that redirects to the same server
    pabx.yousmart.com.br and it worked perfectly
    same nginx rule same ip as server.
yea
certbot 0.31.0
Your host isn't reachable on port 80 (nor on port 443 for that matter). This is required for the challenge. Please open port 80 in your firewall(s) and/or (NAT) router.
An alternative would be to use the dns-01 challenge, but that's way more difficult to set up in most circumstances.
Sorry for the iguinorancia, I can access port 80 by typing pabx.yousmart.com.br or pabx.t3m.com.br, making a test
Status: active
To Action From
22 / tcp LIMIT Anywhere
443 / tcp ALLOW Anywhere
80 / tcp ALLOW Anywhere
Nginx Full ALLOW Anywhere
22 / tcp (v6) LIMIT Anywhere (v6)
443 / tcp (v6) ALLOW Anywhere (v6)
80 / tcp (v6) ALLOW Anywhere (v6)
Nginx Full (v6) ALLOW Anywhere (v6)
how could it release port 80 for cerbot?
thank you.
You can't, this is not an issue with certbot. Your site isn't accessible from the world wide web at all. You can check external sites such as https://downforeveryoneorjustme.com/pabx.t3m.com.br to verify this.
Getting your site up and running for the world wide web is pretty much outside the scope of this Community I'm afraid.
Obrigado é regra de iptables, conseguir resolver, parabens...
Bem-vindo à Comunidade Let's Encrypt, Leandro :slightly_smiling_face:
Eu concordo com as descobertas de Osiris.
Notei um servidor de nomes DigitalOcean. Você está usando um balanceador de carga?
