Certbot: Type:connection; Detail: fetching
http-01 challenge for example.eu
Challenge failed for domain example.eu
   Domain: example.eu
   Type:   connection
   Detail: Fetching
   http://example.eu/.well-known/acme-challenge/dkDTnSTMDoUBIrYmALnKNs_5BVsWJdY_BNQxGZOv_SA:
My web server is (include version): VPS
The operating system my web server runs on is (include version): Ubuntu 20.04 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
MY NGINX CONFIGURATION (/etc/nginx/sites-available/example.eu)
    server_name example.eu;
    listen 80;
         proxy_set_header Host $host;
           client_max_body_size 0;
           add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
           add_header Referrer-Policy "same-origin";
           proxy_pass http://10.8.0.13:5555;
P.S. I linked "example.eu" to /etc/nginx/sites-enabled/
What is more, firewall was disabled, so nothing had to block any traffic.
Welcome to the Let's Encrypt community! :slightly_smiling_face:
I am not able to access or ping cloud hamster.eu. Are you sure your firewall isn't blocking port 80/443? If not, it might be time to check your nginx configuration.
Connection to your domain shows APACHE:
curl -Iki [redacted]
HTTP/1.1 200 OK
Date: Fri, 05 Feb 2021 17:25:08 GMT
Server: Apache
Cache-control: max-age=300
Connection: close
Have you confirmed that DNS is properly resolving the FQDN to the right IP?
