My domain is: http://helpinghumencharitabletrust.org/
I ran this command: sudo certbot certonly --agree-tos --email redacted --webroot -w /var/lib/letsencrypt/ -d helpinghumencharitabletrust.org -d www.helpinghumencharitabletrust.org
and this command too : sudo certbot --nginx -d helpinghumencharitabletrust.org -d www.helpinghumencharitabletrust.org
same problem
It produced this output: Domain: helpinghumencharitabletrust.org
Type: connection
Detail: Fetching http://helpinghumencharitabletrust.org/.well-known/acme-challenge/m2vfq90W-Mo9lQZkAZECyOnSME4rdPCkKnZ7xgCA_iA: Timeout during connect (likely firewall problem)
Domain: www.helpinghumencharitabletrust.org
Type: connection
Detail: Fetching http://www.helpinghumencharitabletrust.org/.well-known/acme-challenge/cbLMXXvPqwRAoL2dLFsH7yDS_qGWSxVCDmHRF43URv8: Timeout during connect (likely firewall problem)
My web server is (include version): nginx/1.18.0
The operating system my web server runs on is (include version): PRETTY_NAME="Kali GNU/Linux Rolling"
NAME="Kali GNU/Linux"
ID=kali
VERSION="2021.2"
VERSION_ID="2021.2"
VERSION_CODENAME="kali-rolling"
ID_LIKE=debian
ANSI_COLOR="1;31"
HOME_URL="https://www.kali.org/"
SUPPORT_URL="https://forums.kali.org/"
BUG_REPORT_URL="https://bugs.kali.org/"
My hosting provider, if applicable, is: nginx
or certbot-auto --version
if you're using Certbot): certbot 1.18.0
Code that i have executed
My domain name is from go-daddy.com
1: sudo openssl dhparam -out /etc/ssl/certs/dhparam.pem 2048
2: sudo mkdir -p /var/lib/letsencrypt/.well-known
3: sudo mkdir /etc/nginx/snippets
4: sudo mousepad /etc/nginx/snippets/letsencrypt.conf
5: sudo mousepad /etc/nginx/snippets/ssl.conf
6: sudo systemctl reload nginx
7: sudo certbot certonly --agree-tos --email redacted --webroot -w /var/lib/letsencrypt/ -d helpinghumencharitabletrust.org -d www.helpinghumencharitabletrust.org
8: after this i got lots of errors i fixed some of them stuck at this now
9: i even run: sudo certbot --nginx -d helpinghumencharitabletrust.org -d www.helpinghumencharitabletrust.org
default nginx conf
```default conf of nginx
listen 80 default_server;
# SSL configuration
root /var/www/html;
server_name _;
include snippets/letsencrypt.conf;
try_files $uri $uri/ =404;
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php-fpm (or other unix sockets):
# fastcgi_pass unix:/run/php/php7.4-fpm.sock;
# # With php-cgi (or other tcp sockets):
# fastcgi_pass 127.0.0.1:9000;
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
#server {
# listen 80;
# listen [::]:80;
# server_name helpinghumencharitabletrust.org www.helpinghumencharitabletrust.org;
# root /var/www/html/;
# index index.html;
# location / {
# try_files $uri $uri/ =404;
server{
listen 80;
server_name 27.7.62.219;
return 301 http://helpinghumencharitabletrust.org;
file in /etc/nginx/conf.d/www.helpinghumencharitabletrust.org.conf
server{
listen 80;
server{
listen 80;
