I am experiencing the same issue at debrog.net (also nginx). My certifcate expired on 8/29/2021, and I can't seem to get a new one:
1: debrog.net
2: mail.debrog.net
3: www.mail.debrog.net
4: www.debrog.net
Requesting a certificate for debrog.net and 3 more domains
Domain: debrog.net
Type: connection
Detail: Fetching http://debrog.net/.well-known/acme-challenge/bFcmJAs8CUtnuVJtMonZlsaWRjZ8nR7LBLCYjWLEj9E: Timeout during connect (likely firewall problem)
Domain: mail.debrog.net
Type: connection
Detail: Fetching http://mail.debrog.net/.well-known/acme-challenge/CW-1dZ2G6q_iYSzYcMi1qVJjYW3NLIcsFVUMD9KrQgs: Timeout during connect (likely firewall problem)
Domain: www.debrog.net
Type: connection
Detail: Fetching http://www.debrog.net/.well-known/acme-challenge/NQ_PND37fHxUB4jOtEwPHLFEJQjUYap7aINRWfIVOVo: Timeout during connect (likely firewall problem)
Domain: www.mail.debrog.net
Type: connection
Detail: Fetching http://www.mail.debrog.net/.well-known/acme-challenge/_EEMpLTGDErW5VjY_86dHhhdHmYQNeTVkUamG_QXB9Q: Timeout during connect (likely firewall problem)
