Expired Certificate... please help urgently
My domain is: www.reboundashby.co.uk
I ran this command: www.reboundashby.co.uk
It produced this output: Privacy error - Your connection is not secure.
The operating system my web server runs on is (include version): Wix
My hosting provider, if applicable, is: Wix
Your certificate is expired.
Since you are using wix, you’ll need to contact their support to resolve this issue.
Thank you
Steven, many thanks for your help. We thought it was a Wix issue but they say it isn’t. It’s half term and we are missing a lot of trampoline park bookings thanks to Wix.
Once again, many thanks for your help.
We really need the answers to these two questions to help you further.
From wix’s support article… it is their issue…
However,
Can you try to turn the certificate off and on again and see if that helps?
Thank you
Hi Steven,
We did turn it off and that obviously resolved the issue. We then tried to turn it back on, hoping it would renew the certificate and have been looking at the following message for 2 days!
SSL Certificate (HTTPS)
SSL certification in progress. This can take up to 1 hour. Still seeing this message? Learn more
Needless to say, learn more tells you nothing.
Wix is an hosted drag and drop so there will be no ssh access or control panel else than wix panel.
In this case… you definitely need to contact their support…
(However I’m wondering since the support states they don’t provide support to custom domain)
P.S. we really want to help you… however, the issue is not with us…
Thank you
Thanks for all your help Steven, much appreciated.
I agree with @stevenzhu—probably only Wix can fix this!
However, it might turn out that there is some other problem that’s preventing Wix from renewing the certificate by itself (e.g. a domain name problem with the domain registrar or something of that nature). But, if so, it would still be easiest for Wix to identify what this problem is and identify which entity can fix it.
WIX SSL Docs states that they generate SSL certs for you.
This means you’re seeing a WIX problem that WIX will have to debug + fix.
