WIX-site HTTPS certificate expired - How to fix?
My domain is: fusen.no
https://crt.sh/?q=fusen.no
A list of certificates that was nicely renewing since april 2017 but now stopped
key issue: What do I do to continue to have certificates issued?
  • Now I have had to turn OFF the https on the site to make it accessible. That is no good
  • When https is ON there is a (bad) warning for my customers trying to reach it.
  • No customers on website == Trouble.
My web server is (include version): WIX website, no server
The operating system my web server runs on is (include version): WIX.com ?
I can login to a root shell on my machine (yes or no, or I don’t know): NA
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): NA
Wix automatically request and deploy certificates to your website and they are the one responsible for any errors reguard your certificate.
Please contact their customer support directly, since (volunteers ok this forum, or let’s encrypt staff) can’t help you with this… (Wix does not allow customer certificate uploads as of now…)
Thank you
Hi @Thor-Christian
your certificate is expired. What happens if you follow this guide:
https://support.wix.com/en/article/enabling-https-for-your-wix-site
Hi Jurgen.
It does not help to switch on/off, I have tried everything I could find… There is no certificate (according to this list: https://crt.sh/?q=fusen.no )
You have two different ip addresses:
D:\temp>nslookup fusen.no.
Addresses: 23.236.62.147
134.170.214.14
Checking the first there is a redirect to https.
Checking the second - oh, an exception, SendFailure, Connection closed unexpectly.
And your www.fusen.no:
D:\temp>nslookup www.fusen.no.
Address: 185.230.62.161
Aliases: www.fusen.no
www111.wixdns.net
balancer.wixdns.net
This is a different ip address.
So you should set your fusen.no - ip addresses to the same values as your www.fusen.no - addresses.
Thank you Jurgen.
You have pointed me in a good direction. I will follow up.
Have a great and sunny weekend.
