Error while running apache2ctl
ress this message
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
Error while running apache2ctl graceful.
httpd not running, trying to start
Action ‘graceful’ failed.
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using mail.tafn.org.uk. Set the ‘ServerName’ directive globally to suppress this message
root@mail:~# certbot --apache
@markymouse,
Something else is using port 80. Run sudo netstat -antup|grep 80 to narrow it down. The right most column should show the application running on that port.
Hope this helps.
