Error Type: connection Detail: Fetching
My domain is: openbooksocial.com
I ran this command:certbot --dry-run certonly
1: Nginx Web Server plugin (nginx)
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)
Select the appropriate number [1-3] then [enter] (press ‘c’ to cancel): 1
Plugins selected: Authenticator nginx, Installer None
Please enter in your domain name(s) (comma and/or space separated) (Enter ‘c’
to cancel): openbooksocial.com
http-01 challenge for openbooksocial.com
Waiting for verification…
Challenge failed for domain openbooksocial.com
    Domain: openbooksocial.com
    Type: connection
    Detail: Fetching
    http://openbooksocial.com/.well-known/acme-challenge/eI2sMNZH0hZ-XJwpw625SzdbauGMG5cex5uvVO2hWaI:
My web server is (include version): nginx version: nginx/1.17.10 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: Linode
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.40.0
Additionally, I can confirm that the firewall is inactive:
root@localhost:~# ufw status
Status: inactive
root@localhost:~# certbot --dry-run certonly
Any Pointers would be helpful. Thanks
If it helps : I am trying to install Mastodon https://docs.joinmastodon.org/admin/install/
Server IP 172.104.239.204
Port 80 is not responding at that IP.
The HTTP site must work before the HTTPS site can work.
I think you transcribed the IP address incorrectly:
$ dig +noall +answer openbooksocial.com
openbooksocial.com.     351     IN      A       172.109.239.204
172.104 is correct, 172.109 isn't.
Hi @vivmajor
your webserver doesn't answer - see https://check-your-website.server-daten.de/?q=openbooksocial.com#url-checks
• http://openbooksocial.com/ 172.109.239.204 -14 10.013 T
Timeout - The operation has timed out
• https://openbooksocial.com/ 172.109.239.204 -14 10.020 T
• http://openbooksocial.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 172.109.239.204 -14 10.026 T
Visible Content:
• https://172.109.239.204/ 172.109.239.204 -14 10.023 T
If an online tool can't connect your webserver, Letsencrypt can't connect your webserver.
172.109.239.204
Brooklyn/New York/United States (US) - Frontier Communications Corporation
No Hostname found
Is that a home server? Allows your ISP port 80?
Works http internal?
curl http://openbooksocial.com/
from that machine?
The IP I have given is correct 172.104.239.204. And if you just look for 172.104.239.204 in the broswer, it gives the Nginx default page.
Looks like there is some mixup somewhere.
Running command :
root@localhost:~# curl http://openbooksocial.com
301 Moved Permanently
Check your DNS records in Softlayer. You will see that you have 172.109 in your DNS A record (some random FCC IP) rather than 172.104 (your Linode).
Your local curl test notwithstanding (which is probably affected by /etc/hosts on that machine), your A record is incorrect.
Ok there was some goofup in IP. Now the IP is 172.104.239.204
I did get the certificate.
But now I have problem starting my nginx.
Blockquote
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2020-06-26 05:15:57 UTC; 1min 4s ago
Docs: man:nginx(8)
Process: 16051 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE)
Jun 26 05:15:57 localhost systemd[1]: Starting A high performance web server and a reverse proxy server...
Jun 26 05:15:57 localhost nginx[16051]: nginx: [emerg] cannot load certificate "/etc/letsencrypt/live/example.com/fullchain.pem": BIO_new_file() failed (SSL: error>
Jun 26 05:15:57 localhost nginx[16051]: nginx: configuration file /etc/nginx/nginx.conf test failed
Jun 26 05:15:57 localhost systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE
Jun 26 05:15:57 localhost systemd[1]: nginx.service: Failed with result 'exit-code'.
Jun 26 05:15:57 localhost systemd[1]: Failed to start A high performance web server and a reverse proxy server.
Blockquote
certbot response:
Blockquote root@localhost# certbot --nginx -d openbooksocial.com
Deploying Certificate to VirtualHost /etc/nginx/sites-enabled/mastodon
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Redirecting all traffic on port 80 to ssl in /etc/nginx/sites-enabled/mastodon
Congratulations! You have successfully enabled https://openbooksocial.com
https://www.ssllabs.com/ssltest/analyze.html?d=openbooksocial.com
    /etc/letsencrypt/live/openbooksocial.com/fullchain.pem
    /etc/letsencrypt/live/openbooksocial.com/privkey.pem
    Your cert will expire on 2020-09-24. To obtain a new or tweaked
    with the "certonly" option. To non-interactively renew all of
    Donating to ISRG / Let's Encrypt: Donate - Let's Encrypt
    Donating to EFF: Support EFF's Work on Let's Encrypt | Electronic Frontier Foundation
Does that REALLY say "example.com" ?
If so, there is your problem.
There is no such cert nor path.
If not, and you just changed it before posting... You missed the real domain in a while lot of other places.
[So I don't really think this was an intentional "coverup" fail]
hi @rg305 No, there is no cover up. Its actually example.com in the output.
In my files I have :
dir /etc/letsencrypt/live/openbooksocial.com/
cert.pem chain.pem fullchain.pem privkey.pem README
Sorry, my bad. Had missed updating site name for letsencrypt setting.
So did you get it working?
My Nginx server is working http://172.104.239.204/
But the server block at https://openbooksocial.com/ with mastodon install, is not redirecting properly.
Any clue would be great. Thanks!
The redirection seems to be looping:
curl -Iki http://openbooksocial.com/
Server: nginx/1.17.10 (Ubuntu)
Date: Fri, 26 Jun 2020 07:30:17 GMT
Content-Type: text/html
Content-Length: 179
curl -Iki https://openbooksocial.com/
Date: Fri, 26 Jun 2020 07:30:20 GMT
Content-Length: 179
HTTP > HTTPS [this is good]
HTTPS > ITSELF [this is bad - endless loop]
Can we see the vhost configs for HTTP and HTTPS?
Thanks.
Do you know your way around NGINX?
If not, show the output of:
grep -Eri 'server_name|SSL|listen' /etc/nginx/
Are you using anything like WordPress?
Not Wordpress. Its Mastodon.
root@localhost:/var/www/html# grep -Eri ‘server_name|SSL|listen’ /etc/nginx/
/etc/nginx/fastcgi.conf:fastcgi_param SERVER_NAME $server_name;
/etc/nginx/uwsgi_params:uwsgi_param SERVER_NAME $server_name;
/etc/nginx/nginx.conf: # server_names_hash_bucket_size 64;
/etc/nginx/nginx.conf: # server_name_in_redirect off;
/etc/nginx/nginx.conf: # SSL Settings
/etc/nginx/nginx.conf: ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
/etc/nginx/nginx.conf: ssl_prefer_server_ciphers on;
/etc/nginx/nginx.conf:# listen localhost:110;
/etc/nginx/nginx.conf:# listen localhost:143;
/etc/nginx/fastcgi_params:fastcgi_param SERVER_NAME $server_name;
/etc/nginx/sites-available/mastodon: server_name openbooksocial.com;
/etc/nginx/sites-available/mastodon: listen [::]:443 ssl ipv6only=on; # managed by Certbot
/etc/nginx/sites-available/mastodon: listen 443 ssl; # managed by Certbot
/etc/nginx/sites-available/mastodon: ssl_certificate /etc/letsencrypt/live/openbooksocial.com/fullchain.pem; # managed by Certbot
/etc/nginx/sites-available/mastodon: ssl_certificate_key /etc/letsencrypt/live/openbooksocial.com/privkey.pem; # managed by Certbot
/etc/nginx/sites-available/mastodon: include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
/etc/nginx/sites-available/mastodon: ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
/etc/nginx/sites-available/mastodon:#listen 443;
/etc/nginx/sites-available/mastodon:# listen 443 ssl http2;
/etc/nginx/sites-available/mastodon: # listen [::]:443 ssl http2;
/etc/nginx/sites-available/mastodon:# server_name openbooksocial.com;
/etc/nginx/sites-available/mastodon:# ssl_protocols TLSv1.2 TLSv1.3;
/etc/nginx/sites-available/mastodon: # ssl_ciphers HIGH:!MEDIUM:!LOW:!aNULL:!NULL:!SHA;
/etc/nginx/sites-available/mastodon: # ssl_prefer_server_ciphers on;
/etc/nginx/sites-available/mastodon: #ssl_session_cache shared:SSL:10m;
/etc/nginx/sites-available/mastodon:# ssl_certificate /etc/letsencrypt/live/openbooksocial.com/fullchain.pem;
/etc/nginx/sites-available/mastodon: # ssl_certificate_key /etc/letsencrypt/live/openbooksocial.com/privkey.pem;
/etc/nginx/sites-available/mastodon: listen 80;
/etc/nginx/sites-available/mastodon: listen [::]:80;
/etc/nginx/sites-available/default: listen 80 default_server;
/etc/nginx/sites-available/default: listen [::]:80 default_server;
/etc/nginx/sites-available/default: # server_name openbooksocial.com;
/etc/nginx/sites-available/default: # SSL configuration
/etc/nginx/sites-available/default: # listen 443 ssl default_server;
/etc/nginx/sites-available/default: # listen [::]:443 ssl default_server;
/etc/nginx/sites-available/default: # Note: You should disable gzip for SSL traffic.
/etc/nginx/sites-available/default: # Read up on ssl_ciphers to ensure a secure configuration.
/etc/nginx/sites-available/default: # Self signed certs generated by the ssl-cert package
/etc/nginx/sites-available/default: server_name _;
/etc/nginx/sites-available/default:# listen 80;
/etc/nginx/sites-available/default:# listen [::]:80;
/etc/nginx/sites-available/default:# server_name example.com;
/etc/nginx/snippets/snakeoil.conf:# Self signed certificates generated by the ssl-cert package
/etc/nginx/snippets/snakeoil.conf:ssl_certificate /etc/ssl/certs/ssl-cert-snakeoil.pem;
/etc/nginx/snippets/snakeoil.conf:ssl_certificate_key /etc/ssl/private/ssl-cert-snakeoil.key;
/etc/nginx/scgi_params:scgi_param SERVER_NAME $server_name;
