Error Type: connection Detail: Fetching
OK, all the “magic” seems to be happening here:
/etc/nginx/sites-available/mastodon
Let’s have a look at that entire file.
root@localhost:/var/www/html# cat /etc/nginx/sites-available/mastodon
map $http_upgrade $connection_upgrade {
  default upgrade;
  ''      close;
upstream backend {
    server 127.0.0.1:3000 fail_timeout=0;
upstream streaming {
    server 127.0.0.1:4000 fail_timeout=0;
proxy_cache_path /var/cache/nginx levels=1:2 keys_zone=CACHE:10m inactive=7d max_size=1g;
  server_name openbooksocial.com;
  root /home/mastodon/live/public;
#root /var/www/html;
 location /.well-known/acme-challenge/ { allow all; }
  location / { return 301 https://$host$request_uri; }
    ssl_certificate /etc/letsencrypt/live/openbooksocial.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/openbooksocial.com/privkey.pem; # managed by Certbot
#listen 443;
#return 301 http://$host$request_uri;
#  listen 443 ssl http2;
 # listen [::]:443 ssl http2;
#  server_name openbooksocial.com;
#  ssl_protocols TLSv1.2 TLSv1.3;
 # ssl_ciphers HIGH:!MEDIUM:!LOW:!aNULL:!NULL:!SHA;
 # ssl_prefer_server_ciphers on;
  #ssl_session_cache shared:SSL:10m;
  # Uncomment these lines once you acquire a certificate:
# ssl_certificate     /etc/letsencrypt/live/openbooksocial.com/fullchain.pem;
  # ssl_certificate_key /etc/letsencrypt/live/openbooksocial.com/privkey.pem;
  keepalive_timeout    70;
  sendfile             on;
  client_max_body_size 80m;
  gzip on;
  gzip_disable "msie6";
  gzip_vary on;
  gzip_proxied any;
  gzip_comp_level 6;
  gzip_buffers 16 8k;
  gzip_http_version 1.1;
  gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
#  add_header Strict-Transport-Security "max-age=31536000";
    try_files $uri @proxy;
  location ~ ^/(emoji|packs|system/accounts/avatars|system/media_attachments/files) {
    add_header Cache-Control "public, max-age=31536000, immutable";
  location /sw.js {
    add_header Cache-Control "public, max-age=0";
  location @proxy {
    proxy_set_header Host $host;
    proxy_set_header X-Forwarded-Proto https;
    proxy_set_header Proxy "";
    proxy_pass_header Server;
    proxy_pass http://backend;
    proxy_buffering on;
    proxy_redirect off;
    proxy_http_version 1.1;
    proxy_set_header Connection $connection_upgrade;
    proxy_cache CACHE;
    proxy_cache_valid 200 7d;
    proxy_cache_valid 410 24h;
    proxy_cache_use_stale error timeout updating http_500 http_502 http_503 http_504;
    add_header X-Cached $upstream_cache_status;
    tcp_nodelay on;
  location /api/v1/streaming {
    proxy_pass http://streaming;
    proxy_buffering off;
    proxy_redirect off;
    tcp_nodelay on;
  error_page 500 501 502 503 504 /500.html;
    if ($host = openbooksocial.com) {
    } # managed by Certbot
  listen 80;
  listen [::]:80;
Please edit your post and add a line above and below with just these three back ticks:
[so we can read it better]
This block doesn’t need to redirect:
  location / { return 301 https://$host$request_uri; } <<<<<<<<<<<<<<<<<<  take this out
This block doesn’t have a listen statement…
So I’m not sure what it does, if anything:
  sendfile             on;
  gzip on;
  gzip_vary on;
  gzip_proxied any;
  gzip_comp_level 6;
  gzip_buffers 16 8k;
  location /sw.js {
  location @proxy {
    proxy_buffering on;
    proxy_redirect off;
    proxy_cache CACHE;
    tcp_nodelay on;
    proxy_redirect off;
    tcp_nodelay on;
So what do you suggest?
Should I include
 listen 443;
Edit :No this does not work.
I suggest you first figure out why that block exists.
There are already two blocks for that FQDN.
The one that listens on 80 - which is doing it’s job just fine (sending everything it hears to 443]
And the one that listens on 443 - which had that extra redirection which you should have removed.
So I don’t know why that third blocks exists nor what you should do with it.
Perhaps it is somehow used/required for mastodon - I would not know.
If so, it might need to go into the block that listens on 443 - but again, I am not sure about it.
I am now getting Error code: SSL_ERROR_RX_RECORD_TOO_LONG
root@localhost: cat /etc/nginx/sites-available/mastodon
  default upgrade;
  ''      close;
upstream backend {
#  root /home/mastodon/live/public;
root /var/www/html;
#    listen [::]:443 ssl ipv6only=on; # managed by Certbot
 #   listen 443 ssl; # managed by Certbot
listen 443;
  sendfile             on;
  gzip on;
  gzip_vary on;
  gzip_proxied any;
  gzip_comp_level 6;
  gzip_buffers 16 8k;
  location /sw.js {
  location @proxy {
    proxy_buffering on;
    proxy_redirect off;
    proxy_cache CACHE;
    tcp_nodelay on;
    proxy_redirect off;
    tcp_nodelay on;
  listen 80;
  listen [::]:80;
Any help?
That happens if you connect a http port via https. Then the port sends a long http answer, https doesn't understand that.
So your port 443 may be now a http port.
Thank you for responding.
Any pointers to solution?
You have created these errors, so you know how to undo that.
Or use a backup with a working configuration.
That makes no sense to me.
Why are redirecting HTTPS to HTTP ?
Also, openbooksocial.com resolves to an IPv4 IP and an IPv6 IP.
Both they don’t both work:
see: https://www.ssllabs.com/ssltest/analyze.html?d=openbooksocial.com
@rg305 I got the site working - seems it was the delay in DNS propagation, as it was corrected two days back.
At https://www.ssllabs.com/ssltest/analyze.html?d=openbooksocial.com - IPV4 is working with A+ now.
But yes for IPv6 something needs to be done.
Thank you for all your support beyond letsencrypt installation.
Sincerely appreciate.
