Done ssl from Let's encrypt but still showing connection is not secure
My domain is: www.pagimalaysia.com
I ran this command: running website
It produced this output: Connection is not secure
Parts of this page is not secure (some images)
My web server is (include version): google cloud VM
The operating system my web server runs on is (include version):bitnami wordpress
I can login to a root shell on my machine (yes or no, or I don’t know):i dont know
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no_bell:
www.pagimalaysia.com this is my domain name
wordpress bitnami
from google cloud
Criteria Email Address = ‘pagimalaysia007@gmail.com’; Issuer CA ID = 1465
Issuer Name C=US, O=“thawte, Inc.”, CN=thawte SSL CA - G2
Certificates
(0) None found
Criteria Identity = ‘pagimalaysia.com
You have a mixed content, which means some content are served in http (plain http) rather than https.
Please use www.whynopadlock.com to fix it.
Direct link: https://www.whynopadlock.com/results/7f0e8369-4aea-4bc3-bc4e-10ee19e2bef4
Hi @pagimalaysialets
your certificate is correct.
Your www-version and your non-www version
is correct.
This is only a mixed content warning problem.
So use FireFox or Chrome, then Ctrl + Shift + I to open the console.
There you see a lot of warnings. Blocked active content.
http://www.pagimalaysia.com/wp-content/uploads/2018/11/cs-icons-manager/mapnearby/style.css?ver=4.9.8
Change these to https.
There are Wordpress settings to define that.
So what next step i have to take?
I need to focus on wordpress,
need to add any plugin?
Thanks for explaining me SSL works
thank u
Your site has something wrong…
I can directly access your dashboard without login…
You might want to fix this before fixing the https mixed content…
Thank you
Thanks for explaining me SSL works n whynopadlock.com benifits
Please check your PM.
Thank you
oh its horible how can it be posible?
what to do?
I’m sorry but i’m not sure why and how to resolve it…
still can u go inside the login dashboard
Unfortunately, yes…
OMG
i got the point
please can u check again becoz i thing now its not posible
Yeah… I can’t access it anymore.
Seems you fixed it.
Stevenzhu… realy man thanks of u…
otherwire if this bug was know by my boss he could fire me
but thank god i recognize that
god bless u dear
