not necessary
sudo /etc/certbot-auto/certbot-auto certonly --authenticator webroot --installer nginx --must-staple --staple-ocsp -d ...
autoindex on;
listen 80 default_server;
listen [::]:80 default_server ipv6only=on;
root /var/www;
server_name example.com;
location ~ /.well-known {
add_header Content-Type text/plain;
allow all;
Congratulations! Your certificate and chain have been saved at: ...
nginx
ubuntu 16.04
Linode
Yes
No
As you can see I succeeded in issuing the certificate.
I set up a dedicated nginx configuration (shown above) just for this purpose.
As I understand, since Jan 2018, the challenge has to be in http, not in https, due to a technical problem.
(Is that correct?)
Note: I don't rely SNI - I only have only one certificate with multiple domains (SAN).
In normal usage, I return the nginx configuration to always forward port 80 (http) to port 443 (https).
But in that state I don't believe it can perform the automatic certificate renewal. (Is that correct?)
I am looking for documentation (or examples) about how to set up the nginx configuration so that it will always forward to 443 (https) except for access to /.well_known , so that auto renewal could be performed.
Also it would be a plus if there were a way to limit access to /.well_known only to letsencrypt.org only at time of auto renewal.
