Help renewing with certbot
My domain is: wayne.host
I ran this command: /opt/certbot/certbot-auto renew
https://mywebsite/.well-known/acme-challenge/RkUGHYZ-**********************
[my ip]: “\r\n401 Authorization
Required\r\n<body
bgcolor=“white”>\r\n
401 Authorization Required</”
My web server is (include version): nginx/1.10.3
The operating system my web server runs on is (include version): Ubuntu 16.04.6 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.35.1
I’m not sure what nginx settings to modify to allow the renewal past my authentication. I already have the following in my config file:
location ^~ /.well-known/acme-challenge/ {
auth_basic off;
autoindex on;
Can you paste Certbot’s complete output, without editing it?
/etc/letsencrypt/live/wayne.host/fullchain.pem (failure)
Hi @mtw145
checking your domain you see the problem ( https://check-your-website.server-daten.de/?q=wayne.host ):
• http://wayne.host/
76.240.241.86 301 https://wayne.host/ 0.304 A
• https://wayne.host/
76.240.241.86 401 1.750 M
Unauthorized
• http://wayne.host/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
76.240.241.86 301 https://wayne.host/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.310 A
Visible Content: 301 Moved Permanently nginx
• https://wayne.host/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 401 1.257 M
Unauthorized
Visible Content: 401 Authorization Required nginx
You have redirects http -> https.
But your https is blocked - 401.
So
  • remove that 401, "/" should work, /.well-known/acme-challenge/unknown-file should answer with a http status 404 - Not Found (or)
  • remove the redirect http -> https, so only http is used to check the validation file.
Really aprecaite the help. I’m very uninformed on this whole topic. Probably why I have this issue in the first place.
" * remove that 401, “/” should work, /.well-known/acme-challenge/unknown-file should answer with a http status 404 - Not Found (or)
  • remove the redirect http -> https, so only http is used to check the validation file."
I’m not exactly how to implement this. Can you be a little more specific?
Check your port 80 vHost. There is a redirect http -> https defined. Remove that redirect to create a new certificate.
Can you also paste the first part of Certbot’s output?
Processing /etc/letsencrypt/renewal/wayne.host.conf
http-01 challenge for wayne.host
Using the webroot path /var/www/html for all unmatched domains.
Waiting for verification…
Challenge failed for domain wayne.host
Attempting to renew cert (wayne.host) from /etc/letsencrypt/renewal/wayne.host.conf produced an unexpected error: Some challenges have failed… Skipping.
    Domain: wayne.host
    Detail: Invalid response from
    https://wayne.host/.well-known/acme-challenge/VD9RLjJUEogqvt_jvXPm9c74WHEd84oq9qvk4qSNnbo
    [76.240.241.86]: “\r\n401 Authorization
    Required\r\n<body
    bgcolor=“white”>\r\n<h 1>401 Authorization Required</”
Is there no way to only accept certbot renewing on http? I don’t really want to remove the redirect for other traffic.
Then remove the 401 blocking of your https port.
https://wayne.host/ -> same problem 401, so you block the complete traffic.
Currently, you don't have https - traffic, all is blocked.
location ~ /.ht {
deny all;
this? I understand what you are saying but don’t know how I am blocking https otherwise.
That blocks fetching the .htaccess -> deny all.
Perhaps you have a blocking command in your .htaccess file if you don't find something in your vHost configuration.
I followed the following example:
listen 80 default_server;
server_name your_dynamic_DNS_address your_server_IP_address;
return 301 https://$server_name$request_uri;
# SSL configuration
listen 443 ssl http2 default_server;
listen [::]:443 ssl http2 default_server;
include /etc/nginx/snippets/strong-ssl.conf;
ssl_certificate /etc/letsencrypt/live/your_dynamic_DNS_address/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/your_dynamic_DNS_address/privkey.pem;
# Root location
root /var/www/html;
# Basic Auth to protect the site
auth_basic "Restricted";
auth_basic_user_file /etc/nginx/.htpasswd;
# Change the client side error pages (4xx) to prevent some information disclosure
error_page 401 403 404 /404.html;
# First attempt to serve request as file, then as directory,
# then fall back to displaying a 404.
try_files $uri $uri/ =404;
# Deny access to .htaccess files, if Apache's document
# root concurs with nginx's one
location ~ /\.ht {
deny all;
# Let's Encrypt Webroot plugin location -- allow access
auth_basic off;
autoindex on;
There
is your blocking rule.
The end looks there is a missing }
And you should create vHosts with explicit server_name values, not default_server.
So one domain (with non-www and www) has one vHost.
will adding the vHosts sole the renewing issue?
I don't know. That depends on your configuration.
There
http://wayne.host/.well-known/acme-challenge/1234
is a 401 - Forbidden, so http-01 validation may not work.
