Certbot nginx does not reload Config
certbot renew --dry-run -vvv
Domain: cloud.faass.eu
Type: connection
Detail: Fetching http://cloud.faass.eu/.well-known/acme-challenge/lGRcvEyPdMBSWjVFkXUCqlmQ7vzmsyp5amZ3YLR8tCU: Connection refused
nginx version: nginx/1.20.2
freebsd-version
12.3-RELEASE-p2
none
no
certbot 1.22.0
Hi!
I am trying to renew my certificate for some days now and tried a lot of things to get it working.
My nginx normally does not listen on Port 80, so I user the nginx-plugin to create a temporary config for the renewal.
When running certbot renew, this config is created and written to /usr/local/etc/nginx and ./letsencrypt:
(nginx.conf):
user www;
worker_processes auto;
This default error log path is compiled-in to make sure configuration parsing
errors are logged somewhere, especially during unattended boot when stderr
isn't normally logged anywhere. This path will be touched on every nginx
start regardless of error log location configured here. See
#147 (nginx touched /var/log/nginx-error.log even when error_log are switched off) – nginx for more info.
#error_log /var/log/nginx/error.log;
pid /var/run/nginx.pid;
load_module /usr/local/libexec/nginx/ngx_stream_module.so;
events {
worker_connections 1024;
http {
include /usr/local/etc/letsencrypt/le_http_01_cert_challenge.conf;
server_names_hash_bucket_size 128;
include mime.types;
and the included file:
root@ProxyDMZ:~ # cat le_http_01_cert_challenge.conf
server{listen 80;server_name cloud.faass.eu;root /var/db/letsencrypt/http_01_nonexistent;location = /.well-known/acme-challenge/mIq4sCUIZmhKstSl-zANhKytN6z61Q_Hm62-zUOa5r0{default_type text/plain;return 200 mIq4sCUIZmhKstSl-zANhKytN6z61Q_Hm62-zUOa5r0.0QTF0O8SjxYNL_GH5X72f2am95dc96J9aE_KZbeEYPU;}}
Problem is: The plugin seems to miss the config reload of nginx, when I look at the open sockets while running the renew only 443 is open.
For testing that I'v copied those two files while the renew was running and failed.
After that point I manually copied both to their directory and did a "service nginx reload", now the Challenge is available and working:
URL="http://cloud.faass.eu"$(cat /usr/local/etc/letsencrypt/le_http_01_cert_challenge.conf | sed -n -e 's/^.location = //p' | sed 's/{.//' )
curl -v $URL
  • Trying 176.198.153.26:80...
  • Connected to cloud.faass.eu (176.198.153.26) port 80 (#0)
GET /.well-known/acme-challenge/mIq4sCUIZmhKstSl-zANhKytN6z61Q_Hm62-zUOa5r0 HTTP/1.1
Host: cloud.faass.eu
User-Agent: curl/7.80.0
Accept: /
  • Mark bundle as not supporting multiuse
    < HTTP/1.1 200 OK
    < Server: nginx/1.20.2
    < Date: Fri, 04 Mar 2022 12:14:35 GMT
    < Content-Type: text/plain
    < Content-Length: 87
    < Connection: keep-alive
    < Strict-Transport-Security: max-age=31536000; includeSubDomains; preload
  • Connection #0 to host cloud.faass.eu left intact
    mIq4sCUIZmhKstSl-zANhKytN6z61Q_Hm62-zUOa5r0.0QTF0O8SjxYNL_GH5X72f2am95dc96J9aE_KZbeEYPU#
Is there anything I can do to tell certbot to reload the nginx config and wait fa few seconds after creating the temp config files?
Or am I missing something different? :wink:
Thanks and greetings from Germany,
Philipp
This sounds like a firewall. Are you accepting connections on port 80?
Starting Nmap 7.92 ( https://nmap.org ) at 2022-03-04 17:35 CET
Nmap scan report for cloud.faass.eu (176.198.153.26)
Host is up (0.057s latency).
rDNS record for 176.198.153.26: ip-176-198-153-026.um43.pools.vodafone-ip.de
Not shown: 998 filtered tcp ports (no-response)
PORT    STATE  SERVICE
80/tcp  closed http
443/tcp open   https
Nmap done: 1 IP address (1 host up) scanned in 6.44 seconds
The easier way to do this is
certbot renew --authenticator standalone --installer nginx
There is but it may not help. My experience is that nginx needs a restart after changing ports listened and the certbot nginx plug-in only does a reload.
@9peppe suggestion for standalone authenticator is a good one. Or,
You should just keep port 80 open always. See this recommendation from LE
But, here is the way to sleep in case you want to try anyway
--nginx-sleep-seconds NGINX_SLEEP_SECONDS
                        Number of seconds to wait for nginx configuration
                        changes to apply when reloading. (default: 1)
This is because I do not have port 80 up and running on nginx when I'm nor renewing my certificate.
Okay, can you tell me what the difference is using the standalone authenticator? Because THIS works, using nginx also as authenticator doesn't:
root@ProxyDMZ:~ # certbot renew --authenticator standalone --installer nginx
Processing /usr/local/etc/letsencrypt/renewal/cloud.faass.eu.conf
Renewing an existing certificate for cloud.faass.eu
Reloading nginx server after certificate renewal
Congratulations, all renewals succeeded:
/usr/local/etc/letsencrypt/live/cloud.faass.eu/fullchain.pem (success)
nginx authenticator needs nginx to listen on port 80.
standalone authenticator spins up a bespoke webserver listening on port 80.
You should make nginx listen on port 80 and redirect to https, there is no reason not to. Then, you can use the nginx authenticator (and the standalone one will fail, because something is already bound to port 80).
