Issue while trying to renew SSL certificate for the first time
I ran this command: ```
certbot certonly --force-renew -d example.com
Error while running nginx -c /etc/nginx/nginx.conf -t.
nginx: [emerg] dlopen() "/opt/bitnami/nginx/modules/ngx_http_geoip_module.so" failed (/opt/bitnami/nginx/modules/ngx_http_geoip_module.so: cannot open shared object file: No such file or directory) in /etc/nginx/modules-enabled/50-mod-http-geoip.conf:1
nginx: configuration file /etc/nginx/nginx.conf test failed
1: Nginx Web Server plugin (nginx) [Misconfigured]
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)
Select the appropriate number [1-3] then [enter] (press 'c' to cancel): 1
Hi @Bhavani, and welcome to the LE community forum :slight_smile:
Please don't use "--force-renew".
It never fixes problems.
What shows?:
certbot certificates
Why not use the bncert tool that is specifically for bitnami?
