DNS problem: SERVFAIL looking up A/AAAA on my domain
services.mambasoft.it
certbot renew
Renewing an existing certificate for services.mambasoft.it
Domain: services.mambasoft.it
Type: dns
Detail: DNS problem: SERVFAIL looking up A for services.mambasoft.it - the domain's nameservers may be malfunctioning; DNS problem: SERVFAIL looking up AAAA for services.mambasoft.it - the domain's nameservers may be malfunctioning
Failed to renew certificate services.mambasoft.it with error: Some challenges have failed.
Apache 2.4.54
openmamba GNU/Linux (2024.4 rolling)
Hetzner dedicated server
Yes
No
2.9.0
I don't think this is your only problem, but one of your authoritative DNS servers (2a01:4f8:151:7444::1 ns3.mambasoft.net) isn't responding over TCP:
ISC EDNS compliance tester result for services.mambasoft.it
Unboundtest, which is a DNS resolver configured very similarly to how Let's Encrypt's servers are configured, with very verbose logging, tries to describe why it's failing to resolve the name, though I haven't quite figured out what's it's trying to say yet.
https://unboundtest.com/m/A/services.mambasoft.it/SFC63S5W
I think it might be related to a broken DNSSEC configuration, not for the mambasoft.it domain, but for the mambasoft.net name that its authoritative resolvers use. Not entirely sure, but maybe it points you in the right direction:
https://dnsviz.net/d/ns3.mambasoft.net/dnssec/
It's also, uh, unusual that there are six NS records listed for mambasoft.net:
ns1.mambasoft.it
ns2.mambasoft.it
ns3.mambasoft.it
ns1.mambasoft.net
ns2.mambasoft.net
ns3.mambasoft.net
With the corresponding .it and .net names having the same IPs. I don't know as it's wrong in any way, but I also don't know if it's what's intended.
Thanks for pointing out some problems on which I'm investigating.
So far I've resolved ns3.mambasoft.net not responding over TCP.
The configuration became this complex, including the six NS for mambasoft.net, because I had to replace glue records for mambasoft.it with mambasoft.net. BTW the six ns entries match the whois record for mambasoft.net.
I'm checking for problems related to DNSSEC on mambasoft.net, it seems ok but DS is missing on parent domain (.net), could it be this the cause? I'm trying to resolve this with my provider or will try disabling DNSSEC.
Yeah, it looks like mambasoft.net is signing but without anyone caring about the signature (because there's no DS record on .net as you say). That shouldn't be causing a problem, though.
Like I said, Unboundtest is trying to say what it doesn't like, but there's just so much logging output that it's hard for mortals to actually understand.
It's not clear for me that Unboundtest says that it doesn't like something, I mean if I ask it to check other well-known domains it doesn't say they are ok or not clearly. Maybe you refer to search, e.g., for "error" matches in lines, in this case I get only this match but I don't know if it may be relevant:
May 24 15:49:04 unbound1.19[2242100:0] debug: outnettcp got tcp error -1
Yeah, the output is hard to parse. So the key result is at the top, saying "status: SERVFAIL". That's the result that Let's Encrypt's servers are returning when you try to get a certificate, as Unbound is reporting that there's an error looking up the domain.
Near the end, it says error: SERVFAIL <services.mambasoft.it. AAAA IN>: exceeded the maximum nameserver nxdomains
But I can't figure out exactly which query it's seeing nxdomains for.
I am now getting correct response for A record using unboundtest
But, AAAA and CAA queries still get SERVFAIL. These records are not required but they must give a proper "not found" and not SERVFAIL.
https://unboundtest.com/m/A/services.mambasoft.it/27AUSDNO
I've removed DNSSEC management a few minutes ago, it does not seem to solve but should simplify the diagnosis.
CAA, A, AAAA for services.mambasoft.it (or what else in the domain) do exist so they can't return "not found", I suppose SERVFAIL is an error definition from Let's Encrypt side. After some or many tries (within days or weeks) I use to have success in renewal, for random reasons, it is frustrating that I can't understand and fix this.
I've found some inconsistency, where sometimes unboundtest worked and sometimes it gave SERVFAIL. Though maybe it's related to changes to the domain happening.
In the last hours I succeeded renewing mambasoft.it, www.mambasoft.it and another subdomain (as said after randomly retrying), services.mambasoft.it is still failing. BTW the problem would come back on next renewal...
I've always had suspects of random network reachability problems from Let's Encrypt servers, even though 3 nameservers in different locations are there for the purpose of ensuring that queries are resolved.
By the way now also services.mambasoft.it succeeded:
Congratulations, all renewals succeeded:
/etc/letsencrypt/live/services.mambasoft.it/fullchain.pem (success)
I've fixed two things: ns3 reachabiity on TCP/IPV6 and disabled DNSSEC but, due to maybe propagation delays, to be sure that the problem is fixed I need to wait and see if I get errors on future renewals.
Thank you all for your help!
Consider combining your certs to handle all your (sub)domains. DNS validation can give you wildcard certificates to ease your workload. Just a thought.
I had a DNS wildcard certificate in the past but it required me to do some implementations to update DNS entries automatically and share certificates between servers, so I opted for the simplest working solution. Maybe I will retry in the future, thanks for the hint.
