My domain is: clearcreek.io
I ran this command: sudo certbot certonly --standalone --preferred-challenges http -d clearcreek.io
Domain: clearcreek.io
Type: dns
Detail: DNS problem: SERVFAIL looking up A for clearcreek.io - the domain's nameservers may be malfunctioning; no valid AAAA records found for clearcreek.io
My web server is (include version): nginx/1.18.0 (Ubuntu)
Ubuntu via WSL2 Distro on Windows 10, made possible by powershell script that allows TCP on ports 80 and 443 and creates a v4 to v4 port proxy.
My hosting provider, if applicable, is: NameCheap
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.29.0
I see others have tried and failed with this. I do have a validated certificate via NameCheap for clearcreek.io (when my servier is turned on), and all functions well. I cannot do the same with certbot.
Possible reasons:
- Must use python or apt to install certbot on this distro; snap will not work as systemd is not included in WSL2 Ubuntu Distros. I have tried both and getting the same error.
*Port forwarding is occurring through my windows 10 PC to the WSL2 instance. I have fixed my PC IP address to be static, and use a script to forward traffic to the WSL2 Ubuntu instance. TCP is allowed in both directions through ports 80 and 443, netsh interface port proxy add v4 to v4 is implemented. But this is working fine with my certificate.
I have also included: location ~ /.well-known {allow all;} on my server block.
I can send along the /var/log/letsencrypt/ log results if helpful, but there are keys etc inside. Please advise.
Thank you!
