DNS problem: NXDOMAIN looking up A for domain name
I’m trying to generate cert for my domain (www.nithyasanghachat.org) and I get this error:
Domain: www.nithyasanghachat.org
Type: None
Detail: DNS problem: NXDOMAIN looking up A for
Env:
  • My Ubuntu 14.04 instance is running on Amazon AWS EC2,
  • I had setup RecordSets in Route 53 as per documentation,
  • I have set my Elastic IP as the A record.
  • I have registered my domain name and got a confirmation as well
  • I’m trying to setup RocketChat in this Ubuntu instance as per their documentation (RocketChat letsencrypt step) and got stuck on this step # 4
  • I tested my domain in https://unboundtest.com/ and got this response:
    Response:
    ;; opcode: QUERY, status: NOERROR, id: 41305
    ;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
Kindly help me resolve this issue.
Thanks,
Shiv
Hi @ishanashivam
there is no public visible ip address ( nithyasanghachat.org - Make your website better - DNS, redirects, mixed content, certificates ):
nithyasanghachat.org A yes 1 0
AAAA yes
www.nithyasanghachat.org Name Error yes 1 0
And Unboundtest doesn't find an answer:
ANSWER: 0
Answer 1 is required.
PS: Two days before:
Thanks for the swift response. When I checked my instance config in AWS, I see that it does have a public ipv4 address.
IPv4 Public IP
18.218.212.200
I also see that this is the ipv4 that I had configured in my A record:
A 18.218.212.200
Is there anything else I need to do to make it public and available?
Using nslookup I don’t see your IP:
D:\temp>nslookup nithyasanghachat.org.  ns-1265.awsdns-30.org.
Server:  UnKnown
Address:  205.251.196.241
The nameserver used is from https://check-your-website.server-daten.de/?q=nithyasanghachat.org - so it’s your name server.
I don’t know if these amazon nameservers are slow.
Oh - checking SOA they are slow:
D:\temp>nslookup -type=SOA nithyasanghachat.org.  ns-1265.awsdns-30.org.
Server:  UnKnown
        primary name server = ns-1937.awsdns-50.co.uk
        responsible mail addr = awsdns-hostmaster.amazon.com
        serial  = 1
        refresh = 7200 (2 hours)
        retry   = 900 (15 mins)
        expire  = 1209600 (14 days)
        default TTL = 86400 (1 day)
nithyasanghachat.org    nameserver = ns-1265.awsdns-30.org
nithyasanghachat.org    nameserver = ns-1937.awsdns-50.co.uk
nithyasanghachat.org    nameserver = ns-383.awsdns-47.com
nithyasanghachat.org    nameserver = ns-842.awsdns-41.net
Ok, I installed certbot and attempted to perform DNS challenge instead of the HTTP challenge. I had also setup an AWS user who has access to change record sets in Route-53. Then I setup those credentials in ubuntu VM to be used by certbot.
But now, I get this error:
DNS problem: NXDOMAIN looking up TXT for
_acme-challenge.nithyasanghachat.org
Is there anything else that I need to do in AWS Route-53 config for the DNS challenge to succeed?
What’s the Certbot command you used, and what’s the full output of the command?
That’s an odd outcome (if it was configured correctly).
This was the command:
sudo certbot certonly -d nithyasanghachat.org -d *.nithyasanghachat.org --dns-route53 -m ishanashivam57@mail.com --agree-tos --non-interactive --server https://acme-v02.api.letsencrypt.org/directory
This was the output:
Found credentials in shared credentials file: ~/.aws/credentials
Plugins selected: Authenticator dns-route53, Installer None
dns-01 challenge for nithyasanghachat.org
Failed authorization procedure. nithyasanghachat.org (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.nithyasanghachat.org, nithyasanghachat.org (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.nithyasanghachat.org
    Domain: nithyasanghachat.org
    Type: None
    Detail: DNS problem: NXDOMAIN looking up TXT for
    Type: None
There are two Route 53 hosted zones for nithyasanghachat.org..
They both have these authoritative NS records:
nithyasanghachat.org.  172800  NS  ns-383.awsdns-47.com.
nithyasanghachat.org.  172800  NS  ns-842.awsdns-41.net.
nithyasanghachat.org.  172800  NS  ns-1265.awsdns-30.org.
nithyasanghachat.org.  172800  NS  ns-1937.awsdns-50.co.uk.
But one is in fact hosted on ns-1766.awsdns-28.co.uk. and 3 other com, net and org nameservers.
Certbot might be finding and modifying the hosted zone that isn’t in active use.
Wow, I dont know why Route-53 registrar created one more HostedZone, while I was creating one.
In any case, I deleted the HostedZone in whose config I kept adding recordsets.
Now when I ran the same command, my certificate got created. Yay!!!
Thanks for that valuable pointer.
