Certificate DNS problem
herdtrails.com, www.herdtrails.com
sudo -H /opt/letsencrypt/letsencrypt-auto certonly --standalone -d herdtrails.com -d www.herdtrails.com
http-01 challenge for herdtrails.com
http-01 challenge for www.herdtrails.com
Waiting for verification…
Failed authorization procedure. www.herdtrails.com (http-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up A for www.herdtrails.com, herdtrails.com (http-01): urn:ietf:params:acme:error:unknownHost :: The server could not resolve a domain name :: No valid IP addresses found for herdtrails.com
    Domain: herdtrails.com
    Type: unknownHost
    Detail: No valid IP addresses found for herdtrails.com
    Domain: www.herdtrails.com
    Type: None
    Detail: DNS problem: NXDOMAIN looking up A for www.herdtrails.com
Amazon Linux AMI
amzn-ami-hvm-2017.09.0.20170930-x86_64-gp2 (ami-1a7f6d7e)
https://aws.amazon.com/amazon-linux-ami/2018.03-release-notes/
AWS, Route 53
Yes
No
n/a
Hi @AskBid
checking your domain ( https://check-your-website.server-daten.de/?q=herdtrails.com ) there is no ip address defined. Not ipv4, not ipv6.
herdtrails.com A yes 1 0
AAAA yes
www.herdtrails.com Name Error yes 1 0
So you can't use http-01 - validation.
You need webspace and a running webserver if you want to use http-01 validation.
You can use dns-01 validation, but then you have to create a dns txt entry.
isn't EC2 instance with nginx good for the job?
But your domain isn't public visible. So Letsencrypt can't validate you are the domain owner.
why is it not visible?
maybe it takes time after registration?
I am not an expert i simply followed this tutorial:
all because I was trying to get CORS support for this json file I am trying to use in Observablehq:
I guess I simply have to give up as I don’t have enough knowledge to set up such a thing
The first link has something:
You should have four record sets now, two of Type “A”, one “NS” and one “SOA”. The values for “NS” are your Name Servers.
Did you create such an A record? I must be able to see your A record, Letsencrypt must be able to see your A-record.
I think http://herdtrails.com works now?
Then recheck your domain https://check-your-website.server-daten.de/?q=herdtrails.com - then you will see, if the tool is able to see your domain.
If yes, then try to create a new certificate.
Nameserver entries are cached, but the tool and Letsencrypt check the authoritative name server.
I tried without www:
[root@me ec2-user]# sudo -H /opt/letsencrypt/letsencrypt-auto certonly --standalone -d herdtrails.com
Problem binding to port 80: Could not bind to IPv4 or IPv6.
does it mean that is the same problem as before? in that case I have no idea how to proceed.
but at least now http://herdtrails.com works
If you have a running webserver, why do you use standalone? Standalone starts an own webserver, but then port 80 must be free. But your webserver blocks port 80.
Please read the basics:
I see, now you have created a certificate.
Most is ok, but rechecking your domain ( https://check-your-website.server-daten.de/?q=herdtrails.com ) there is one thing:
http://herdtrails.com/
52.56.73.140 200 0.054 H
http://www.herdtrails.com/
52.56.73.140 200 0.050 H
https://herdtrails.com/
52.56.73.140 200 1.530 B
https://www.herdtrails.com/
52.56.73.140 200 1.293 N
Certificate error: RemoteCertificateNameMismatch
You have created two dns A entries. With non-www (herdtrails.com) and www. But your certificate has only one domain name:
CN=herdtrails.com
	02.02.2019
	03.05.2019
	herdtrails.com - 1 entry
So your www - version isn’t secure.
So create one certificate with both domain names and use that instead. Change your working command to something like
then one certificate with both domain names is created.
