Problems DNS problem: NXDOMAIN looking up A
cartonpremium.soytraspalacio.com
sudo certbot --nginx -d cartonpremium.soytraspalacio.com -d www.cartonpremium.soytraspalacio.com
Requesting a certificate for cartonpremium.soytraspalacio.com and www.cartonpremium.soytraspalacio.com
  Domain: www.cartonpremium.soytraspalacio.com
  Type:   dns
  Detail: DNS problem: NXDOMAIN looking up A for www.cartonpremium.soytraspalacio.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.cartonpremium.soytraspalacio.com - check that a DNS record exists for this domain
nginx version: nginx/1.24.0
ubunto 22.04
no
certbot 1.21.0
Just like it says, there's no DNS record for www.cartonpremium.soytraspalacio.com. You probably either want to:
  1. Set up that DNS record, and your server, so that users typing in that name with the www. on it will get to your site. At which point, you'll be able to get a certificate for that name. Or,
  2. Remove the -d www.cartonpremium.soytraspalacio.com from your request, if you don't need to support that www. name.
As confusing as it may be to some people, a domain name with www. on it and without are really two completely separate names as far as Internet infrastructure is concerned.
thanks I was setting up cartonpremium.soytraspalacio.com, I'll have my time to learn later about www. is best or what is the point to have it
