Could not issue an SSL/TLS certificate
My domain is carle.co.in
I am trying to generate from plesk.
web server : iis
error
Could not issue an SSL/TLS certificate for bigcash.co.in
Details
Could not issue a Let's Encrypt SSL/TLS certificate for bigcash.co.in .
Failed to connect to the Let's Encrypt server https://acme-v02.api.letsencrypt.org .
Please try again later or report the issue to support.
Details
Could not obtain directory: cURL error 28: Failed to connect to acme-v02.api.letsencrypt.org port 443: Timed out (see libcurl - Error Codes)
@sakag Please open a new Help topic for your problem and answer the questions on the form the best you can. Thank you
[moved]
closed due to duplicate topic now open
