Could not issue an SSL/TLS certificate
Hello!
Iam using Plesk normaly to get Let´s Encrypt SSL / TLS certs but since today i am getting this message on all domains.
Any ideas how i can get a solution for it?
Could not issue an SSL/TLS certificate for xxxxxxxxxspaceholderxxxxx
Details
Could not issue a Let's Encrypt SSL/TLS certificate for xxxxxxxxxspaceholderxxxxx.
Failed to connect to the Let's Encrypt server https://acme-v02.api.letsencrypt.org.
Please try again later or report the issue to support.
Details
Could not obtain directory: cURL error 35: error:1409441B:SSL routines:ssl3_read_bytes:tlsv1 alert decrypt error (see libcurl - Error Codes)
Can you show output of this from that machine?
curl -v https://acme-v02.api.letsencrypt.org/directory
What is your operating system and version.
