Could not issue an SSL/TLS certificate for webmapasia.com
My domain is: webmapasia.com
CPU DO-Premium-AMD (1 core(s))
Version Plesk Obsidian v18.0.36_build1800210604.22 os_Ubuntu 20.04
OS Ubuntu 20.04.3 LTS
Key number PLSK.08260938.0000
I ran this command: SSL/TLS Certificate
Details
Could not issue a Let's Encrypt SSL/TLS certificate for webmapasia.com . Authorization for the domain failed.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/31710677740.
Details:
Type: urn:ietf:params:acme:error:dns
Status: 400
Detail: No valid IP addresses found for webmapasia.com
Hi @huanvuduc, welcome to the LE community forum :slight_smile:
You need a functional HTTP site before you can secure it (via HTTP authentication).
The first thing on that list is having an IP address.
webmapasia.com does not resolve to an IP address.
You need to update the DNS zone to return the IP address of that DO server.
OR
Your current nameserver list might also need to be modified - if they aren't the ones where you are going to maintain your DNS zone.
The current authoritative list shows:
webmapasia.com  nameserver = ns-cloud-d1.googledomains.com
webmapasia.com  nameserver = ns-cloud-d2.googledomains.com
webmapasia.com  nameserver = ns-cloud-d3.googledomains.com
webmapasia.com  nameserver = ns-cloud-d4.googledomains.com
When DO nameservers are queried, an IP address is returned:
Address: 159.203.111.207
And when a DO nameserver is asked: Who are the authoritative nameservers for your domain?
They only list DO nameservers:
nslookup -q=ns webmapasia.com ns1.digitalocean.com
webmapasia.com  nameserver = ns1.digitalocean.com
webmapasia.com  nameserver = ns2.digitalocean.com
webmapasia.com  nameserver = ns3.digitalocean.com
So it seems that you just need to update your nameservers at your domain registrar.
