Could not issue an SSL/TLS certificate in Plesk
Have created a new site in Plesk on a temp domain but cannot get the SSL to issue, keep getting the following error, although we already have one site that has a valid certificate on this IP
Could not issue an SSL/TLS certificate for sad-cray.10-1-0-4.plesk.page
Details
Could not issue a Let's Encrypt SSL/TLS certificate for sad-cray.10-1-0-4.plesk.page . Authorization for the domain failed.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/52262046490.
Details:
Type: urn:ietf:params:acme:error:dns
Status: 400
Detail: No valid IP addresses found for sad-cray.10-1-0-4.plesk.page
That hostname resolves to the IP address 10.1.0.4 which cannot be used for the http-01 or tls-alpn-01 challenges. If you're using a private IP address, you can only use the dns-01 challenge to validate the hostname.
"How would I do that in Plesk", you might ask? No idea..
Thanks for the response, it was the conclusion I came to in regard to Plesk, no idea on how you do it
I do not know Plesk either but maybe try the Plesk forums?
Some starter ideas
Have done, none of them work
Why are you using IP 10.1.0.4?
[even if you get a cert, no one (on the Internet) will be able to reach that IP]
Do you plan on serving any Internet clients?
What is the purpose of the cert?
